Page 3 of 3 1 2 3
Re: Dana 60 or 9 inch [Re: BobR] #457194
09/03/09 12:10 PM
09/03/09 12:10 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I wouldnt discredit a dana because of weight.
I swapped my broken 8.75 out for a dana and saw nothing ET wise by doing the swap, in spite of gaining about 35-40 pounds, and having added b body drum brakes on to the equation at the same time( a body 8.75 and smaller a body drums were what car had).. Must be the dana is effecient, and the weight is in a place it doesnt hurt.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Dana 60 or 9 inch [Re: B3422W5] #457195
09/03/09 12:22 PM
09/03/09 12:22 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Because a Dana or strange 60 just looks right sitting under a mopar...
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: Dana 60 or 9 inch [Re: instigator] #457196
09/03/09 02:00 PM
09/03/09 02:00 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
who cares what rear ya use!!!! run what ya brung and what you can afford..
and Happy Birthday Gilberto...
Re: Dana 60 or 9 inch [Re: smokinwoody] #457197
09/03/09 02:32 PM
09/03/09 02:32 PM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
Re: Dana 60 or 9 inch [Re: instigator] #457198
09/03/09 06:44 PM
09/03/09 06:44 PM
Q
Quicktree Offline
Quicktree  Offline
Q
as it does under a ford truck
Re: Dana 60 or 9 inch [Re: Quicktree] #457199
09/03/09 07:24 PM
09/03/09 07:24 PM
Locomotion Offline
Locomotion  Offline
That was one of Ford's "Better Ideas"!
Re: Dana 60 or 9 inch [Re: Locomotion] #457200
09/03/09 07:52 PM
09/03/09 07:52 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I will never understand the 9 3/4 "haters".
Re: Dana 60 or 9 inch [Re: RemCharger] #457201
09/04/09 02:22 PM
09/04/09 02:22 PM
Virginia
MACDiesel Offline
MACDiesel  Offline
Virginia
Check out the June '08 issue of Car Craft. They did a 9" vs 12bolt vs dana 60 shoot out.
For the street, it kinda comes down to: when do you need a 9.75" ring gear? Or a super strong 9"? Then again, if your racing, bigger is better.
The good ole 8 3/4 can handle a ton of power. Why not stick with the lighter (faster) set up?
Oh yeah, a BIG, FAT to Car Craft for throwing the ford 8.8 in that article and leaving out the 8 3/4!
-1967 Belvedere II 440/4speed
Re: Dana 60 or 9 inch [Re: MACDiesel] #457202
09/04/09 02:30 PM
09/04/09 02:30 PM
Q
Quicktree Offline
Quicktree  Offline
Q
well stick around a while and you will see a few dozen good ole 8 3/4s bite the dust. on a street car they will last forever. throw a real set of slicks, a little weight, and decent hp anf they are gone.
Re: Dana 60 or 9 inch [Re: Quicktree] #457203
09/04/09 04:32 PM
09/04/09 04:32 PM
Virginia
MACDiesel Offline
MACDiesel  Offline
Virginia
Really? Even the build Moser ones?
Re: Dana 60 or 9 inch [Re: MACDiesel] #457204
09/04/09 04:38 PM
09/04/09 04:38 PM
Q
Quicktree Offline
Quicktree  Offline
Q
the ring and pinion will always be the weak point no matter what you name it or how it's built. if I were going to use an 83/4 it would be an aluminum case.
Re: Dana 60 or 9 inch [Re: MACDiesel] #457205
09/04/09 04:44 PM
09/04/09 04:44 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Yep....the ring and pinion are what they are, no matter how you surround them
1.41 best 60 foot
6.56 at 104.17
Re: Dana 60 or 9 inch [Re: B3422W5] #457206
09/04/09 04:54 PM
09/04/09 04:54 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Re: Dana 60 or 9 inch [Re: Quicktree] #457207
09/04/09 05:44 PM
09/04/09 05:44 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
being down in a similar part of the world it was easier & cheaper for me to build an aftermarket floater 9" than a dana 60. vendors with Dana gear want waaay more than than 9" vendors. i have the Strange Nodular head, & spool with richmond gears & Romac floaters & a local boy made me some awesome axles for under $500 of our $$ which equates to $300usd.
Re: Dana 60 or 9 inch [Re: rebel] #457208
09/04/09 07:14 PM
09/04/09 07:14 PM
Arizona
Chris'sBarracuda Offline
Arizona
This argument seems to come up quite often..
But I guess there always be just about as many for one as the other..
My take on this is that when you are at the track and you have an issue with a 9"...There will most likely be someone there who has what you need in his trailer..Have seen it many many times..
Fairly easy fix in the pits with a 9"...Not so much with a Dana..
Chris..
Re: Dana 60 or 9 inch [Re: Chris'sBarracuda] #457209
09/05/09 12:22 AM
09/05/09 12:22 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
But......The Dana wouldn't be broke...Now would it???
Learned my lesson, and seen a bunch of 9" stuff go awol too. Strange60 Dana in mine now.
Re: Dana 60 or 9 inch [Re: superwrench] #457210
09/05/09 01:22 AM
09/05/09 01:22 AM
Arizona
Arizona
I personally have never broke a 9"..I don't have enough power.. But I was in Denver for a race and wanted to try a 5.29 gear.. There were several guys that had spares for me to just pop in.. That was my personal experience.
Now I have 2 sets of third members.. 1 for altitude..
Chris..
Re: Dana 60 or 9 inch [Re: Chris'sBarracuda] #457211
09/05/09 01:39 AM
09/05/09 01:39 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Hi,
thanks for all the ideas.
dr diff thanks.
anyone from down here knows how pricey any choice is to be made up.
have borrowed a 4.1 8 3/4 for next weekend .if the car likes it through the trap it wll be a dana.
if not a 9 inch.
bearing in mind i have only been running a 3.91 rear gear.
and yes it easier to obtain the 9 inch stuff
BUT the dana is cooler we'll see
thanks again
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Dana 60 or 9 inch [Re: tex013] #457212
09/05/09 01:43 AM
09/05/09 01:43 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
3.90 gears are also available for Dana 60 rears. In fact, I just shipped a set to Strange Engineering.
Page 3 of 3 1 2 3
