Re: Dana 60 or 9 inch
[Re: tex013]
#457175
09/02/09 08:03 PM
09/02/09 08:03 PM
Posts: 16,931 NC
440Jim
NC
3710lb
This will have people on both sides. But the weight makes me think Dana 60.
[Re: 70HemiGTX]
#457178
09/02/09 08:51 PM
09/02/09 08:51 PM
Posts: 6,149 Melbourne , Australia
LA360
Ring a few places and see what they have in stock, and what needs to be ordered in and a lead time. Dana stuff seems to be a little tricky to get here in Melbourne, but anyone who specilises in Ford F Truck differentials should carry abit of it. AL...
Alan Jones
[Re: bdaz smblk]
#457180
09/02/09 08:53 PM
09/02/09 08:53 PM
LA360
Pro Stock runs a 9.5" center section. Alot of Comp Eliminator guys with run a Strange GM 12 Bolt centre in a 9" Housing. AL....
Alan Jones
[Re: DoctorDiff]
#457182
09/02/09 09:07 PM
09/02/09 09:07 PM
Quicktree
Once again, the big boys don't run 9" rearends, they run 9.5" and larger.
There is virtually NO weight difference between a NEW S-60, and a comparable NEW 9" with fab housing.
I know, but why?
[Re: LA360]
#457183
09/02/09 10:18 PM
09/02/09 10:18 PM
Posts: 2,470 Sydney,Australia
tex013
Sydney,Australia
Al, noone has much dana on the shelf.a qld ford f guy does have the best selection.to get a good 9" is around 4 weeks minimum,noone seems to carry axles definately no mopar ends.i can air freight a strange dana in for about the same or 2-300 more looks like a dana will be it.will try a 4.11 8 3/4 centre in the mean time at The Nationals next week.this also gives me a chance to try this ratio as i only have a 3.89 at the moment.i do run a 29.5" street tyre,28" et street radial strip,so i don't think the ratio change will hurt on the street or top end.Traps at 6000/6100 @118+ now thanks for all thoughts Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#457184
09/02/09 11:47 PM
09/02/09 11:47 PM
LA360
It gets quite annoying at time when people don't stock Mopar stuff. I think with the current Ecconmonic climate, alot of companies are ordering parts as required. I know Q Pac in QLD were machining their own axles in house, I don't remember the turn around. It's been a while since I have had to buy alot of this stuff, and I imported it all myself anyway. Some of it, EG - The gears, I would have been better off buying locally. (The freight was ridiculous) AL....
Alan Jones
[Re: blown572dart]
#457185
09/03/09 09:26 AM
09/03/09 09:26 AM
Posts: 8,165 Left Coast
BobR
Left Coast
aftermarket 9" all the way.
As do I. As for the parasitic power loss the aftermarket addressed this long ago and there are 9.5's available(Dewco)that are far more efficient than the Dana. And Cass was right about using the 9.5 and larger for ultimate performance. Any pro stock cars run the Dana? Any comp cars? For the street the Danas are great. For the track the benefits of the Ford type rears are numerous.
[Re: S/ST 3040]
#457188
09/03/09 11:11 AM
09/03/09 11:11 AM
Quicktree
Oh man........that picture is going to open another can of worms.
Happy Birthday Gilberto!
you mean the bad pinion angle
[Re: Quicktree]
#457189
09/03/09 11:13 AM
09/03/09 11:13 AM
Quicktree
really it's hard to tell anything with out the car setting on the ground
[Re: SB449VALIANT]
#457192
09/03/09 11:24 AM
09/03/09 11:24 AM
Quicktree
Thanks Vic...
yea Happy Birthday
[Re: bdaz smblk]
#457193
09/03/09 12:03 PM
09/03/09 12:03 PM
BobR
Left Coast
ok , whats the power limit on a dana? why doesn't SS/AH still run them? why don't pro stockers run them if they are faster?
Because there is alot better gear selection for a 9".
There is a whole lot more to it than this. A WHOLE LOT.
