Another Indy 360-1 rocker question #456364
09/01/09 11:32 AM
09/01/09 11:32 AM
Lubbock,TX
DavidDean Offline OP
Lubbock,TX
Will the Norris W-2 W-5 rockers work on the Indy 360-1 heads? The intake rockers measure about .785 offset. Thanks
Re: Another Indy 360-1 rocker question [Re: DavidDean] #456365
09/01/09 01:02 PM
09/01/09 01:02 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
If you machine the pedestals & offset the holes, yes, I have done it before. As long as intake rocker has enough offset, you can put almost anything on an ICH head with enough machining.
Re: Another Indy 360-1 rocker question [Re: RyanJ] #456366
09/01/09 02:32 PM
09/01/09 02:32 PM
Lubbock,TX
Lubbock,TX
Thank you!
