Re: tranny code
[Re: anlauto]
#456280
09/01/09 01:18 PM
09/01/09 01:18 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
D21 just tells you four speed. The number on the transmission tells you which four speed and for which application.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
Re: tranny code
[Re: 70 buzz]
#456282
09/01/09 03:54 PM
09/01/09 03:54 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The number stenciled on the case is the last three digits of the transmission part number. (Same three digits are on build sheet)
Re: tranny code
[Re: John_Kunkel]
#456284
09/01/09 05:09 PM
09/01/09 05:09 PM
Posts: 1,893 michigan
70 buzz
michigan
Great have a build sheet number 674. thanks for your help
Re: tranny code
[Re: cataclysm80]
#456285
09/02/09 12:01 PM
09/02/09 12:01 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
Which helps you if you have your build sheet.
Do auto trans cars get these stenciled numbers too? (all trans got them right?)
Tav
No the auto trans has the part number stamped on the pan rail
Re: tranny code
[Re: cataclysm80]
#456287
09/03/09 09:28 AM
09/03/09 09:28 AM
JohnRR
U.S.S.A.
So it's manual trans only. Is that both 3 speed & 4 speed manual trans?
Tav
I will ASSuME the 3 speed has it , but otherwise yes manual trans ONLY, at least I have NEVER seen it on an auto trans , I'm sure someone will come up with a picture of one now that I used the word ONLY
