2001 Durango R/T with 46re trans. Changed the fluid to Amsoil synthetic two years ago (or was it three?), at about 65,000 miles (*I think*). The magnet had a lot of powder on it, so I figure the fluid hadn't been changed since new (bought it with 50,000 on it).
So I'm getting set to put a new aluminum pan on it (more capacity, drain plug, and temp sender hole) and the magnet has more stuff on it again. Maybe not as much as last time, but definitely more than I would expect after 15 or 20K miles.
It shifts fine, doesn't slip (well, maybe just a little going up a hill while in OD at just over 35 mph), doesn't rev between shifts, doesn't come out of TC lockup when it shouldn't. However, the fluid still had a red tint to it, with a hint of brown, and admittedly, it did smell a little burnt.
No chips or filings, just powder. Will a band adjustment and new fluid take care of it?
(BTW, the new pan doesn't fit because of the 3" exhaust system, so back to the exhaust shop. Not necessary just for the new pan, but because I had to drop the trans x-member to get the old pan out also.
As always, TIA.
-Marq
