vacuum advance cans interchange between distributors? #455323
08/31/09 07:49 AM
08/31/09 07:49 AM
Grand Haven, MI
patrick Offline OP
patrick  Offline OP
Grand Haven, MI
in tuning my new engine combo, I found that the vacuum advance can is DOA on my dizzy. I was wondering if they are interchangeable between the factory electronic ignition dizzy's (what I have) and the older points style? I'm thinking an older app might have a can with a little less total advance built in (I'd like one with ~14-15 degrees, my dead one has 17 degress, most I've found are ~22), which would suit my combo better.
also, does anyone know if the aftermarket ones from Standard or Airtex are adjustible like the factory ones?
thanks in advance
2017 Grand Cherokee Overland
Re: vacuum advance cams interchange between distributors? [Re: patrick] #455324
08/31/09 09:25 AM
08/31/09 09:25 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes the electronic one will fit a points and vice versa , I turned a new electronic unit i had into a points unit , just swapped the breaker plate and the points cam , the factory is adjustable so i'm a bit confused on your total amounts quoted . , never checked the aftermarket units to see if they are adjustable but I would assume they are ???
Re: vacuum advance cams interchange between distributors? [Re: patrick] #455325
08/31/09 09:49 AM
08/31/09 09:49 AM
iirc the cans wont interchange as the angle of the arm is different between the two but it has been decades since I was mixing/matching parts on that deal. You could (even JB ) weld something on both sides of the stop so it cant be pulled in as far like 2 little snips of wire of the right thickness. As double R said I'd be surprised if the aftermarket ones weren't adjustable also.
Re: vacuum advance cams interchange between distributors? [Re: JohnRR] #455326
08/31/09 12:05 PM
08/31/09 12:05 PM
Grand Haven, MI
patrick Offline OP
patrick  Offline OP
Grand Haven, MI
the adjustment on the cans are only for preload--when the vac advance begins advancing. the length of the slot on the arm determines the total advance.
Re: vacuum advance cams interchange between distributors? [Re: patrick] #455327
08/31/09 12:38 PM
08/31/09 12:38 PM
hooziewhatsit Online content
hooziewhatsit  Online Content
When I got my truck, I found my vac advance can was seized up as well.
I found two different kinds in the junkyard. From the top the arm on one hooked left and back (mine), and the other hooked right and back. They were enough off from each other you'd have to do a lot of customizing to make the wrong one work.
Weirdly, the one I got in the junkyard does not have a stamp on it saying how much advance it provides.
Re: vacuum advance cams interchange between distributors? [Re: patrick] #455328
08/31/09 01:24 PM
08/31/09 01:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I didn't know that , I assumed that adjusting the spring pressure changed the amount it advanced ? Good thing I run them disconnected I guess
Re: vacuum advance cams interchange between distributors? [Re: JohnRR] #455329
08/31/09 05:06 PM
08/31/09 05:06 PM
Az
Crizila Offline
Crizila  Offline
Az
Vacuum advance units are great mileage improvers and will help your modified engine run better -( idle and cruise imparticular ). If you are doing an all out race car, chuckem. On the street or dual purpose, useem - IMO.
Fastest 300
Re: vacuum advance cans interchange between distributors? [Re: patrick] #455330
08/31/09 09:48 PM
08/31/09 09:48 PM
wv
Dartcuda Offline
Dartcuda  Offline
wv
NAPA sells vacuum advance units with different degrees of actuation to fit mopar distributers , just look them up in one of their paper catalogs. I have found that the 8.5 (17 degrees) works best , gives 52 degrees total with 35 degrees of mechanical. They are adjustable.
Re: vacuum advance cans interchange between distributor [Re: Dartcuda] #455331
08/31/09 10:00 PM
08/31/09 10:00 PM
Grand Haven, MI
patrick Offline OP
patrick  Offline OP
Grand Haven, MI
I think that's what I'm going to go for....was spending some time on rockauto, and it looks like airtex #4V1084 or Standard Motor Products VC184 is the 8.5 one (which is what was on my dizzy that went bad) was wondering if there was a 7.5 one out there (15 degrees advance)
Re: vacuum advance cams interchange between distributors? [Re: Crizila] #455332
09/01/09 08:15 AM
09/01/09 08:15 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I knew someone would take the bait ...
Re: vacuum advance cams interchange between distributors? [Re: JohnRR] #455333
09/09/09 10:29 AM
09/09/09 10:29 AM
Grand Haven, MI
patrick Offline OP
patrick  Offline OP
Grand Haven, MI
update-
picked up a Standard Motor Products VC184, it's app is for an '88 dodge 1 ton 360. has 17 degrees advance (most others are 22), and is adjustable for the tip-in point, like OEM.
2 days later and $23 shipped to my door from rockauto. all the local parts stores wanted about $40 and 7-10 days for them.
