Re: what timing chain for 418 stroker @500hp
[Re: hp340nos]
#455085
08/31/09 08:46 AM
08/31/09 08:46 AM
Posts: 52,972 Romeo MI
MR_P_BODY
motor im putting together is a 340 .040 4"crank,pump gas roughly 500hp,ive always used cloyes in the past,but was looking at progear timing chain set,what is the better set-up a 3 keyway or a 7 keyway,i see the keyways are in the cam gear on the progear,cam is a herbert solid roller 108* lobe seperation, i will be installing it at 104* do the multi keyways help for timing advancing or retarding or will i still have to use offset keys also thanks mike
When I use to use a chain I used Cloyes set up but if you want to get the advance dead on you will most likely still need the offset keys.... now days I've been using a KB gear drive
[Re: hp340nos]
#455087
08/31/09 11:32 AM
08/31/09 11:32 AM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
The Pro-Gear is a nice piece but, key-ways in cam gear can be confusing. They are indexed in camshaft degrees as opposed to crankshaft degrees. i.e. If you need to advance cam 2º you only move it 1º on the cam gear. I've used the off-set keys to dial them in, even when using multi-keyed gears.
[Re: knyech1]
#455091
09/01/09 07:37 AM
09/01/09 07:37 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
Cloyes are not what they used to be. They use a cheap chain now and do not last.
I have a Pro Gear on my hemi now that I got from DRAM, very nice piece and is supposed to be a quality chain. CHIP
