Electronic Ignition Problems #454432
08/30/09 12:49 PM
08/30/09 12:49 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Hello again all-knowing Moparts members! Yet another question for everyone. I tried looking this up on the search forum but was unsuccessful.
My dad is putting together 68 'Net with a 383 and went against my advice and bought a Mopar Performance Electronic Ignition Kit with a chrome box. I printed off all the info on this website as far as install instructions, and the install seemed to be good. The engine started, for a couple seconds, then died. The same thing happened again, started and died, and wouldn't start. Battery was dead ALREADY!!! Chrome module was HOT along with the wires. Any suggestions???? I hooked it up like it said, what could be the problem?? This resto has been a nightmare for my dad and I feel terrible he is almost done and wanting to sell it and all this nonsense and is real real down about it. Any help would be amazing. Thank you everyone
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: Electronic Ignition Problems [Re: knyech1] #454433
08/30/09 01:15 PM
08/30/09 01:15 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Absolutely nothing wrong with a correctly installed Mopar system.Is this the diagram you used???
Re: Electronic Ignition Problems [Re: MoparforLife] #454434
08/30/09 01:27 PM
08/30/09 01:27 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Yeah printed out the whole thing off this site! Had my meter out checking voltage and checked his resistor for correct spec and everything. But there has to be something I am missing. I hooked up my duster like 8 years ago with that system and had no problems. But on the other side of the spectrum I didn't have anything to troubleshoot so I really don't know what to look for.
Re: Electronic Ignition Problems [Re: knyech1] #454435
08/30/09 05:57 PM
08/30/09 05:57 PM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
Try another box? I had a chrome one not last long at all once,try just a orange box if available.
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
