Do you think my hood scoop is a problem? #454283
08/30/09 08:57 AM
08/30/09 08:57 AM
Salina ks
572_dup2 Offline OP
Back On The Bumper!!
572_dup2  Offline OP
Salina ks
I have 6" cowl front carb has about 3/4 clearnace. Both carbs are maybe 2" from from top. Car does not pull like it should in second an high gear. Would it help if i had holes in front of scoop with an air pan?
Shawn Jennings
Re: Do you think my hood scoop is a problem? [Re: 572_dup2] #454284
08/30/09 09:25 AM
08/30/09 09:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The 2" isnt bad but I prefer more space... if you dont
have a pan to seal off the carbs I would do that first.
In a conventional scoop you would like the air horn
about 3/4" below the bottom of the inlet of the scoop.
A ideal entry is also preferred on each carb to help
let the air make the 90% turn instead of a shear.
If you can see in the cowl.... a little test is to
tape a bunch of 2" long pieces of yarn in a bunch
of places under the top of the cowl to see the air flow
(cheap wind tunnel testing)
Post deleted by Defbob [Re: MR_P_BODY] #454285
08/30/09 11:31 AM
08/30/09 11:31 AM
Re: Do you think my hood scoop is a problem? #454286
08/30/09 11:33 AM
08/30/09 11:33 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
run it without the hood. i hate hoods
Re: Do you think my hood scoop is a problem? [Re: 572_dup2] #454287
08/30/09 01:52 PM
08/30/09 01:52 PM
Q
Quicktree Offline
Quicktree  Offline
Q
well how did your night at the races go? or did I miss it somewhere?
Re: Do you think my hood scoop is a problem? [Re: Quicktree] #454288
08/30/09 02:17 PM
08/30/09 02:17 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
I did run with the hood off. It slowed down alot!
Shawn Jennings
Post deleted by Defbob [Re: 572_dup2] #454289
08/30/09 03:38 PM
08/30/09 03:38 PM
Re: Do you think my hood scoop is a problem? #454290
08/30/09 03:47 PM
08/30/09 03:47 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
a total lack off air control which can reduce the airflow into the carbs. it acts like a siphon when crossing the carb openings
Put two K&N substacks on the carbs and that will take care of that problem.
Re: Do you think my hood scoop is a problem? [Re: cudabunch] #454291
08/30/09 05:40 PM
08/30/09 05:40 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
I knew a guy who put a tunnel ram and on his 440 66 Dart and the car went from 10.90's to 10'70s and the hood got broken and He ran it without and put birdcatcher on it and went 10.50's. I figured it would slow about 2 tenths without hood but it went the other way. I still have trouble believing it. Must have trapped a lot of air under the hood?
Re: Do you think my hood scoop is a problem? [Re: Lil Wedge] #454292
08/30/09 08:26 PM
08/30/09 08:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm betting he would have gone a little quicker with
the hood AND the bird catcher... I'm sure the bird
catcher was directing the air much better
Re: Do you think my hood scoop is a problem? [Re: MR_P_BODY] #454293
08/30/09 08:32 PM
08/30/09 08:32 PM
get rid of the cowl hood and put on a taller version of mine.
then youll have the nostalgia look and get functionability.
how bad did it run today?
i got my all time best today in bad air.
Re: Do you think my hood scoop is a problem? [Re: 572_dup2] #454294
08/30/09 09:32 PM
08/30/09 09:32 PM
Arizona
Chris'sBarracuda Offline
Happy Birthday Chris'sBarracuda  Offline
Arizona
Then ignore my other post..
Chris..
