race gas compared to E85 when converted
#454044
08/29/09 11:19 PM
08/29/09 11:19 PM
Posts: 123 long beach,ny
10sec340
long beach,ny
I have in another topic the problem i am having affording race gas on the streets in my Dart, one idea was to turn my motor into pump gas another just convert to E85. I want to hear dyno #'s or track times from those guys that have tried this conversion...... was it worth it? did you drop off allot ?
Thanks, Tim The Legend
real 383 car now 440..
Re: race gas compared to E85 when converted
[Re: MR_P_BODY]
#454046
08/30/09 08:20 AM
08/30/09 08:20 AM
10sec340
long beach,ny
what about delivery fuel system ? I have a magna fuel 500 pump and filter, 2port regulator .
Tim
[Re: 10sec340]
#454047
08/30/09 08:42 AM
08/30/09 08:42 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Tim
Your system need to pump at least 30% more volume over gas... I use the same pump(pumps in my case, 2 Holley black 150's) and a 4 port Mallory return style reg, all these were used on my 1050 dom on my race gas set up then I changed to a 1050 dom on E-85
[Re: 10sec340]
#454048
08/30/09 08:52 AM
08/30/09 08:52 AM
Posts: 16,930 NC
440Jim
NC
was it worth it?
An easy YES Race gas $9.25/gallon, E85 $2.29/gallon. That pays for the conversion in short order. And E85 runs a little cooler. I changed more than just the carb, so my ET is not a direct fuel comparison. I estimate the E85 was 0.15 faster than gas, and methanol was another 0.15 faster than E85 in hot summer weather. The differences get smaller in colder air.
[Re: 10sec340]
#454049
08/30/09 08:55 AM
08/30/09 08:55 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Now you've hot me thinking about it...Does anyone know if Holley 2300, 2-barrel sixpack carbs can be modified to have enough fuel flow capacity to run E85 and feed nearly 700 hp?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#454050
08/30/09 09:10 AM
08/30/09 09:10 AM
MR_P_BODY
I dont see why not... your increasing the amount of fuel not the air so if you have enough air flow you would just need to increase the fuel volume by 30% across the board... I dealt with Quick Fuel so you might talk to them
[Re: MR_P_BODY]
#454051
08/30/09 09:36 AM
08/30/09 09:36 AM
10sec340
long beach,ny
wish I would have gone this route before the summer, I would still have $$ left on my Sunoco Gas card !!!!!!!!!
I will be starting this conversion after the 8th(i have a track rental)
Cant wait !!!! Just dont tell anybody I went "Green" I hate tree huggers !!!
[Re: 10sec340]
#454052
08/30/09 11:19 AM
08/30/09 11:19 AM
Mr. Legend,Van Jones will love you for it! He's in charge of the "Green Energy" department! I also plan on making the switch,as soon as I can afford a new QFT 950,and get my E-Heads shaved for 12:1 compression. RandyB
[Re: MR_P_BODY]
#454053
08/30/09 08:32 PM
08/30/09 08:32 PM
jbc426
West Coast, USA
Thanks for the tip. I found a 500 CFM E85 2bbl that's used for circle track racing on their website. It looks like with a little modification to the top of the carb it would be a bolt on replacement. It sure would be nice to have a trio of 500CFM E85 carbs under my shaker. I'm going to have to give them a call tomorrow to see how much that would set me back, and if they think it can be made to work on my application.
[Re: roadrunnerreds]
#454057
08/30/09 09:45 PM
08/30/09 09:45 PM
MR_P_BODY
Mr Peabody should i do the volume check first with gas and then figure from that? Brad
Really you need to figure your engine consumption as it is now then figure 30% more and see if your fuel system will do at least that much
[Re: EchoSixMike]
#454058
08/30/09 09:51 PM
08/30/09 09:51 PM
MR_P_BODY
Is there a problem with E85 ruining oil like is the case with methanol? S/F....Ken M
No its nothing like meth... get get it warmed up before your run... I get to about 185 degrees at the end of my run each time and when I get back to my pit spot and shut it down it back to about 165... I havent seen hardly any oil contamination, I went last season with 1 oil change mid season and it still looked good
[Re: MR_P_BODY]
#454059
08/30/09 10:11 PM
08/30/09 10:11 PM
10sec340
long beach,ny
summit has kits for the dominator by quick fuel for only $270 !! dam if thats all it takes I'll be set up right after the 8th track day !!!
I'm getting excited over here !!!!!!!!!
[Re: challenger73400]
#454063
08/31/09 08:01 PM
08/31/09 08:01 PM
10sec340
long beach,ny
what about the concern that it's not always e85, some times it on 70 -75 or winterblends?
