what should I set lash at? #453624
08/29/09 07:16 PM
08/29/09 07:16 PM
KY
juicedcuda Offline OP
KY
I was wondering how to find the number to set my lash at? Is it based on my cam specs?
http://i98.photobucket.com/albums/l269/carlyjosh/camcard-1.jpg
Here is a copy of my cam card and the only difference is I am running 1.7 ratio rockers.
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: what should I set lash at? [Re: juicedcuda] #453625
08/29/09 07:28 PM
08/29/09 07:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well your card says .026 for both... see if you can
tighten it up some if it will make more power... its
something you need to play with
Re: what should I set lash at? [Re: MR_P_BODY] #453626
08/29/09 07:30 PM
08/29/09 07:30 PM
KY
KY
Oh, so that's where it is located on the card, under valve adj....lol . First time with an adjustable valvetrain.
Now is that with everything cold?
Re: what should I set lash at? [Re: juicedcuda] #453627
08/29/09 07:36 PM
08/29/09 07:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It didnt say hot or cold so I would guess its cold.
I have tightened mine up(which is just looser than
yours .028) to .019 and thats where I run my cam (
that is hot)
