pump gas SB stroker ignition timing??? #452544
08/28/09 02:25 PM
08/28/09 02:25 PM
Phoenix
jinxy Offline OP
jinxy  Offline OP
Phoenix
How much total timing do you run?
Jeff
Re: pump gas SB stroker ignition timing??? [Re: jinxy] #452545
08/28/09 02:29 PM
08/28/09 02:29 PM
Az
Crizila Offline
Crizila  Offline
Az
Mines been real happy with 31 degrees. Gonna bump it up to 35 and try it next time out, but I don't expect much / any improvement.
Fastest 300
Re: pump gas SB stroker ignition timing??? [Re: Crizila] #452546
08/28/09 02:36 PM
08/28/09 02:36 PM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
34-36 seems about right for me.
Re: pump gas SB stroker ignition timing??? [Re: LAR_414] #452547
08/28/09 02:53 PM
08/28/09 02:53 PM
Phoenix
jinxy Offline OP
jinxy  Offline OP
Phoenix
Thanks guys
My Mopar electronic dist has about 25 degrees advance so I'll try 10 initial and 35 total.
Re: pump gas SB stroker ignition timing??? [Re: jinxy] #452548
08/28/09 05:48 PM
08/28/09 05:48 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
You'll probably find it wants more initial advance. My 408 has a msd dist with 18 degs of advance- with 35 total it still wants more initial. I'm thinking about getting an aftermarket bushing to let me run more initial with the same total...
Re: pump gas SB stroker ignition timing??? [Re: radar] #452549
08/28/09 06:48 PM
08/28/09 06:48 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Mine seems happy with 21* initial and 34* total.
Re: pump gas SB stroker ignition timing??? [Re: justinp61] #452550
08/28/09 08:33 PM
08/28/09 08:33 PM
Phoenix
jinxy Offline OP
jinxy  Offline OP
Phoenix
I'm hoping it will idle ok at 10 degrees initial.
I may need to get a different distributor.
Re: pump gas SB stroker ignition timing??? [Re: jinxy] #452551
08/28/09 09:56 PM
08/28/09 09:56 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
what cam do you have? whats the specs? if its anything over 240 @ .050, you need at least 18 initial. it wont idle right
Re: pump gas SB stroker ignition timing??? [Re: aarcuda] #452552
08/29/09 01:36 PM
08/29/09 01:36 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
The msd distributor is great but if you are handy you can weld up the slot in your stock dist. to limit centrifugal advance. There is a chart floating around here somewhere if you search. I went through all this and had to learn fast- I knew NOTHING about all this stuff when I dove in not too long ago. Try searching for my posts on this stuff- the help I got can help you.
Or just spend the money on the pro billet. The only downside is the lack of vac. advance if you want max gas mileage. Other than that it is really easy to install and tune.
Good luck
rdr
