What is the lowest profile M/W port intake?? #451936
08/27/09 04:27 PM
08/27/09 04:27 PM
Illinois, Indiana, Louisiana
ProStDodge Offline OP
I am looking for the shortest M/W port intake I can find. 1 or 2 4bbl, or maybe even a blower manifold.
I really want to use my Hilborn Shotgun injector hat as a throttle body for my twin turbo setup, but would also like to keep it under the hood.
With the turbos and Indy Big EZ cnc heads, I doubt a short intake will affect flow very much, but I need to find one with ports to match the heads.
I have already had the hat converted to EFI
Re: What is the lowest profile M/W port intake?? [Re: ProStDodge] #451937
08/27/09 04:45 PM
08/27/09 04:45 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I think this will be as low as you can possibly get.
1963 Max Wedge NASCAR Single Plane 2408156.
I have seen pictures of one but couldn't find any on the internet. Maybe someone else can help. LOL, probably cost more than a custom made sheetmetal intake.
Re: What is the lowest profile M/W port intake?? [Re: ProStDodge] #451938
08/27/09 04:57 PM
08/27/09 04:57 PM
Suburb of Chicago, IL
BCFKody Offline
BCFKody  Offline
The MP P4876337 intake. It is a low profile intake that is 1.250 inches shorter than a Super Victor or the Indy 440-2 intake.
It was designed to work with Max Wedge heads on a RB block. It has a built in valley tray. If you use it with Indy heads, then you need to use the Indy valley plate in addition to the "337" intake, because the Indy intake ports are slightly raised. Do a search on AndyF posts. He attached lots of pics.
Re: What is the lowest profile M/W port intake?? [Re: BCFKody] #451939
08/27/09 05:16 PM
08/27/09 05:16 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I tried to get Hemi Fred to use one of those Shotgun scoops on his twin turbo Hemi. It would work good on a tunnel ram intake or maybe the blower intakes with an adapter, IMO.
http://speed.racingjunk.com/category/128...-Big-Block.html
Floyd Lippencott IV
