Re: Dodge Avenger .....front suspension help
[Re: wj440]
#45167
11/23/07 10:37 PM
11/23/07 10:37 PM
Posts: 499 ohio
wj440
ohio
[Re: wj440]
#45169
11/24/07 12:08 AM
11/24/07 12:08 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Walt, How bought making an Alterkation front end fit, buy your back half kit, and have a chassis shop tie it all together with a certified cage? It may be kinda pricey but may save alot of work and frustration. But I've never done any of this so I'm clueless.
[Re: ProSport]
#45170
11/24/07 12:28 AM
11/24/07 12:28 AM
Posts: 2,584 sycamore,ohio
BobsProFab
sycamore,ohio
Walt, we put toghether a daytona years ago with a kit that bolted in, we used dodge carravan struts and brakes. im thinking it was a mopar kit. not sure if one would work for that car. i can get a little more info from the guy if you want Bondo
[Re: wj440]
#45174
11/26/07 09:47 PM
11/26/07 09:47 PM
Posts: 368 back home in georgia ,lake sid...
105630
I'm will be getting you some pictures real soon ,have been building a new house and work is wide open,but the engine will be pulled soon to be some updating on combination and will be able to get you some pretty detailed pictures then. The pics I had before are lost and I'm sure you will like the new ones soon ,but the car does still have the factory strut tower,the front tube off the cage passes thur the tower and tries into the front clip and the strange strut attaches to the bar up top and uses a viper control arm on the bottom ,which attaches to the bottom part of the bottom rail rails which try in also up front below the top bars but you will be able to see and tell so keep watch in a week or so and I'll make sure to pm you also,may also have the car up for sell soon rolling chassis but it going to be priced in the 30's STILL CHEAPER than you can built these days.SORRY FOR THE DELAY..
[Re: smokinwoody]
#45178
11/27/07 02:22 AM
11/27/07 02:22 AM
that is such a cool slide show Dave,,,the Avenger is looking real sharp...nice chassis
very nice! Looking good!Looks like your planning on some serious HP for sure.
[Re: Chad Bittle]
#45180
11/27/07 05:27 PM
11/27/07 05:27 PM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
wj440 - you want to replace a strut front end with a strut front end? What am I missing about the stock stuff?
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
[Re: BBR]
#45181
11/27/07 06:56 PM
11/27/07 06:56 PM
Posts: 687 Ohio
Chad Bittle
Ohio
we're turnin it into a big block (hopefully), back halved, street/strip car. The biggest problem we're having is how to change the front suspension and still use the stock shock tower locations if possible.....just lookin for pictures and ideas from people that know of or have done this kind of thing before so we don't cut out or get rid of anything and regret it later.
[Re: BBR]
#45182
11/27/07 06:59 PM
11/27/07 06:59 PM
dartman366
Mt. Vernon, Ohio
no, wanting to put an aftermarket strut set-up in the place of a stock strut set-up and have somewhere to mount the lower portion of the strut and engine, a big portion of the existing K frame(if that's what you would call it) will have to be cut out to clear the transmission, trying to stuff a V8 in it and make it look as stock as possible,,,looking toward's street/strip.
[Re: BBR]
#45184
11/27/07 08:48 PM
11/27/07 08:48 PM
Posts: 626 Mid-Ohio
Bakaruda432
mopar addict
mopar addict
Mid-Ohio
[Re: Bakaruda432]
#45185
11/27/07 09:53 PM
11/27/07 09:53 PM
Posts: 12,339 somwhere
smokinwoody
somwhere
Man that sounds Nasssssssty!!!
Love ta have more of those pics!!!
down boy....my PC is getting wet...
here....heres a bone...
