BIG tires on a 70 Cuda: stock wheelwells vs. mini tubs.
#450948
08/26/09 03:51 PM
08/26/09 03:51 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Hi!
I am currently installing subframe connectors on my 71 cuda.
My wheel wells are rusty and so is my trunk floor....my frame rails are fine though.
While I was at it....I was thinking that it would be cool to have some extra space under there to stuff BIG tires if I wanted to.
I was wondering, if I use one of Dr. Diffs bolt on spring relocation kits with offset shackles....how big of a tire could i fit under the stock wheel wells? From what I have seen, Dr. Diffs kit will position the leafspring just in line with the stock inner wheel well wall at its narrower point.
Now, if I went ahead and mini tubbed the car by stretching the inner wheel well as far as the stock subframe will let me go... How much more tire coukld I be able to fit? Also, when you do this: can you will be able to mount the rear seat back in place as original? I want to keep the car looking bone "stock".
Also, when you relocate the springs to the subframe on an E Body, how do you mount the rear spring shackle? On an A body its a piece of cake because the rear frame is parallel to the leafsroing and all you do it hand the shackle on the frame, but on an E Body the frame is not parallel to the leafspring,,,,how do you address this on an E Body?
Thanks!!!
Domingo
Re: BIG tires on a 70 Cuda: stock wheelwells vs. mini tubs.
[Re: domingo]
#450951
08/27/09 11:30 AM
08/27/09 11:30 AM
Posts: 309 Hampden, Maine
Procommuter
super street
super street
Hampden, Maine
On my '73 Barracuda I am modifing the outer wheel house so that my tires will stop rubbing. If you examine the outer wheel house it does not follow the quarter panel up, it goes up and in at a much shallower angle. My tires have always rubbed on a big bump so I couldn't lower the ride height at the back of the car. I have cut out the offending area and I will replace it with something that looks like a section of a wheel tub.
Wes
73 Barracuda 440 EFI 4 speed, 144.85 MPH LTA A/FSS Record Holder.
[Re: Procommuter]
#450952
08/27/09 02:33 PM
08/27/09 02:33 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
My Challenger is minitubed with coilovers holding it up and I fit a M/T 31*13 on a 10" wheel with 6 7/8" backspacing.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
