setting ignition timing? #450539
08/26/09 11:45 AM
08/26/09 11:45 AM
california
sbcjd Offline OP
sbcjd  Offline OP
california
If I turn the distributor in the direction of the rotor rotation in a small block will that advance or retard the timing?
Re: setting ignition timing? [Re: sbcjd] #450540
08/26/09 11:51 AM
08/26/09 11:51 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Advance.
Re: setting ignition timing? [Re: sbcjd] #450541
08/26/09 11:57 AM
08/26/09 11:57 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Turning the distributor housing in the SAME(clockwise) direction will RETARD the timing.
Re: setting ignition timing? [Re: sbcjd] #450542
08/26/09 11:58 AM
08/26/09 11:58 AM
retard
Re: setting ignition timing? [Re: RapidRobert] #450543
08/26/09 01:07 PM
08/26/09 01:07 PM
Upper Midwest
Upper Midwest
You guys are right - I was just working on a BB puller truck last night and had that on my mind. Sorry for any inconvenience. I admit mistake.
Re: setting ignition timing? [Re: MoparforLife] #450544
08/26/09 01:19 PM
08/26/09 01:19 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Works the same on big blocks as small blocks.
Re: setting ignition timing? [Re: goldmember] #450545
08/26/09 01:56 PM
08/26/09 01:56 PM
Upper Midwest
Upper Midwest
I know but for some reason I had clockwise/counter clockwise in my hed. CC for BB and CW for SB. Again Think I will go back out and clean corral for a while. Maybe I can do that right.
