Re: 413 stroker build question ?
[Re: MO_PA]
#44951
09/26/07 09:00 PM
09/26/07 09:00 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
Thanks! Alyerpal2
Maybe someone will chime in with the info for rods.
looks like a 6.760 would work but your choices on that length are pretty much stock mopar big end rods . not sure what clearance issue you might have with internal oil pickup ?
[Re: Mopar-Al]
#44953
09/27/07 07:37 AM
09/27/07 07:37 AM
i'm building one right now. 4.25 crank and 7.1 chevy rods at 4.250 bore for 482 c.i. it should make a great street/strip combo and very pump gas friendly.
[Re: Mopar-Al]
#44954
09/27/07 08:04 AM
09/27/07 08:04 AM
JohnRR
I was going to say a 6.760 rod but he said he was useing a 383 piston so I wasnt sure about pin height on the piston. Or what piston height he needs. The 4.15 crank will work on the rb block and internal oiling , but with stock journals he will have to use a side grinder on the internal tube thread hole area to thin it up some. There is enough material there to do this. I have built a dozen rb engines with that combo, but 4.375 bore not 4.25.
i did the math to come up with that rod , he said 383 piston and i assumed shelf stock pistons . with that in mind the only 2 i know of , actually there are 3 and i didn't plug that in , is the speedpro forged , which is super heavy , or a diamond at 1.32 . but diamond also has a stroker piston for use with the std low deck rod and i don't have that CH handy so that may be the other alternative and get one a BBC spec rod and the smaller rod journal .
but it looks like dan has it coverd , but that rod length needs a 1.5ish CH piston ???
[Re: Rug_Trucker]
#44957
07/25/08 09:54 PM
07/25/08 09:54 PM
Posts: 2,042 Leucadia, Ca.
vdriver
Leucadia, Ca.
Put a set of open chamber heads on them and the cast crank is cheap
Storker crank is cast? Or the 413 is?
I was wondering the same thing. Never heard of a cast crank 413.
[Re: dOc !]
#44960
07/26/08 02:05 AM
07/26/08 02:05 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
No, not a 4.15 cast, but there was an Eagle 4.15 that puked out last week on Ebarf for $400 and considering what I put into a 3.75 for a 451 build to AVOID the Chinese crank in that build it's down right CHEAP! Even if it is Rice! I'd love to build a 413 into a 470 with LY rods and one of the 440souce 4.15 $600 cranks and some 383 pistons! CHEAP! I bet I could build close to a 470hp short block for $1200 with some left over parts the last set of 383 pistons I saw went for less then a hundred bucks I used a slanty 6 crank that was welded on the rod journals 30 years ago and it was B-E-A-UTIFUL! Not sure the skill is out there to do it at that level today Certainly not at the cost compared to offshore
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
