727 tranny toast?-UPDATE-NOT TOAST! :) #448872
08/25/09 09:35 AM
08/25/09 09:35 AM
Washington, PA.
69charger383 Offline OP
Washington, PA.
A friend just bought a 68 charger 383/727 combo. The car runs & drives real good. He drove the car home from the seller's house which was 450 miles away without any problems at all. When we started checking the car over, we discovered there is no kickdown linkage for the tranny. Someone pulled the kickdown lever on the tranny all the way forward & put a spring on it to keep it there. My friend said he did not get on it at all on the way home & babied it. Is this tranny toast, or if he puts a kickdown set-up on it (Bouchillon kit)& sets it properly will it be OK? He said when he was checking out the car, he was so excited, he just didn't notice that the linkage was not there.
Re: 727 tranny toast? [Re: 69charger383] #448873
08/25/09 09:45 AM
08/25/09 09:45 AM
SK, Canada
E
etek Offline
etek  Offline
E
SK, Canada
Guess the only way to know is to set up the linkage and try it. Can't see how it would be toast if it drove 450miles! It also must have gone through the gears with that much driving. I've seen guyd remove/disable the kickdown becuase it was binding, bent, etc. As you know, it just "kicks down" the gears when you boot it (old term!)...let us know what happens!!!
Re: 727 tranny toast? [Re: etek] #448874
08/25/09 10:07 AM
08/25/09 10:07 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
First smell the fluid and then pull it half way open/back) (tie strap or wire) go for a ride should shift well but upshifts will be higher. then get a kit from whomever (mancin's has them) summit??
Re: 727 tranny toast? [Re: Dodgem] #448875
08/25/09 10:12 AM
08/25/09 10:12 AM
scratchnfotraction Offline
hook the Bouchillon kit and try it
50/50 chance IMO
may get lucky,as it seems to be working still,and he took it easy on the trip...
good luck
Re: 727 tranny toast? [Re: scratchnfotraction] #448876
08/25/09 11:19 AM
08/25/09 11:19 AM
The "kickdown linkage" really only increases line pressure.
If it was babied then there is a good chance it's OK.
Really, though, if you don't know it's history the seals and clutch material is going to be pretty well shot unless it was rebuilt at some point.
I just did a '73 727 with 60k orignal miles. While it looked VERY nice inside there was evidence that the bands and the clutches were starting to flake after 35 + years of use and the seals were hard and brittle as well.
Re: 727 tranny toast? #448877
08/25/09 11:23 AM
08/25/09 11:23 AM
Berwyn, IL
challenger70 Offline
Berwyn, IL
Wouldn't it being held all the way forward have the line pressure at the max and have prevented burning anything up? Or do I have it backwards
Re: 727 tranny toast? [Re: challenger70] #448878
08/25/09 11:27 AM
08/25/09 11:27 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Max pressure is all the way back.
Re: 727 tranny toast? [Re: stumpy] #448879
08/25/09 11:30 AM
08/25/09 11:30 AM
Berwyn, IL
Berwyn, IL
Then why would you put a spring to keep it there? Some of the stuff you find on these cars will make you go nuts
Re: 727 tranny toast? [Re: challenger70] #448880
08/25/09 11:59 AM
08/25/09 11:59 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Because the person that did it is a MORON .
Re: 727 tranny toast? [Re: etek] #448881
08/25/09 12:00 PM
08/25/09 12:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That statement couldn't be more WRONG ...
Re: 727 tranny toast? [Re: JohnRR] #448882
08/25/09 12:11 PM
08/25/09 12:11 PM
Berwyn, IL
Berwyn, IL
I am far from an expert but I am continually amazed at the # of people that do not know this and tell people to just ditch the kickdown, etc....
Re: 727 tranny toast? [Re: etek] #448883
08/25/09 01:11 PM
08/25/09 01:11 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
WRONG The kick down linkage is a misname for the throttle pressure control linkage which more than anything else controls pressures in the transmission throughout the travel of the throttle and controls shift points with out clutch slippage.
Re: 727 tranny toast? [Re: etek] #448884
08/25/09 04:37 PM
08/25/09 04:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Another GOTCHA for the "who cares what it's called" crowd.
Re: 727 tranny toast? [Re: MoparforLife] #448885
08/25/09 05:29 PM
08/25/09 05:29 PM
SK, Canada
E
etek Offline
etek  Offline
E
SK, Canada
SORRY GUYS!!! That's what I was always taught - my apolgies for bringing BAD info to the game!!!
But my appreciation for the better info. Funny, becuause I knew it increased line pressure, but thought that's what held it in gear longer...isn't that what it would do in the end??
Re: 727 tranny toast? [Re: etek] #448886
08/25/09 05:33 PM
08/25/09 05:33 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yup something to do with more pressure takes the govner longer to overcome that so it does two things at once raises pressure to bands and clutches and the more it's open the higher the shift point!
I think the valve body and govener are magic??
Re: 727 tranny toast? [Re: etek] #448887
08/26/09 02:50 PM
08/26/09 02:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You and a vast number of other Mopar affectionados. Join the crusade to end the use of the term "kickdown" linkage.
Re: 727 tranny toast? [Re: John_Kunkel] #448888
08/26/09 03:16 PM
08/26/09 03:16 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
Is it toast ? .. as has been suggested above look at the fluid and if it is not brown .. probably NOT.
With what you have now .. "tie" the lever HALF WAY back and then test-drive it with it under part-throttle only.
SEE how it shifts and how the gear-changes engage. If that is OK .. to make you feel better - just change the ATF and filter and you should be good-to-go.
Re: 727 tranny toast? [Re: BeEtLeJuIcE !] #448889
08/27/09 05:33 AM
08/27/09 05:33 AM
Berlin, Germany
Flo Offline
Flo  Offline
Berlin, Germany
If you drain the fluid... adjust the bands!
Just did the regular maintenance on my original 67 727, which started screwing up the 1-2 shifts. When I got the car someone had disengaged the linkage too, no idea how long it was run like that.
Adjusted the bands and the linkage, changed fluid and filter. Installed the smallest Transgo towing shift improver kit with conservative setting (drilled the holes to the medium size they suggested). Have a perfectly shifting transmission.
1967 Fury III 4door HT tiny 318, late model roller block, bored and stroked to 344
Re: 727 tranny toast?-UPDATE-NOT TOAST!! :) [Re: 69charger383] #448890
09/24/09 10:03 AM
09/24/09 10:03 AM
Washington, PA.
Washington, PA.
Hi everyone. On my 58 Belvedere...I'm a happy camper right now ...my tranny isn't toast!!! I put the Bouchillon trans cable on my tranny, adjusted it properly, changed the fluid & filter (even though it was red) & adjusted the bands. I test drove it for over 100 miles the past weekend & it shifts perfectly now without any problems! I also got my emerg. brake cables set up on & working good(another post). It's nice when things go good Thanks for the input everyone!
Re: 727 tranny toast?-UPDATE-NOT TOAST!! :) [Re: 69charger383] #448891
09/24/09 12:09 PM
09/24/09 12:09 PM
Berwyn, IL
Berwyn, IL
Good deal
