Indy 360-1 Header Tube size #447974
08/24/09 10:24 AM
08/24/09 10:24 AM
HOUSTON,TEXAS
FIREGUY12 Offline OP
HOUSTON,TEXAS
Looking to get a set of custom headers built for my 71 Plymouth duster. Would like to know some recommendations on header tube size and length. The car as tube k-member with rack and pinion so i have plenty of room.
Some of the engine specs.(Small block)
360-1 Indy heads CNC
3.79 stroke, 4.060 bore 394 ci
14:1 comp
1050 domnator carb
roller cam ??????
weight just guessing 3000-3100lbs.
Should I builg 1 7/8-2 inch steps.
2-2 1/8 steps
or straight 2 inch.
Any suggestions or advice would be appreicited. thanks.
Re: Indy 360-1 Header Tube size [Re: FIREGUY12] #447975
08/24/09 11:34 AM
08/24/09 11:34 AM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
c.i. are little less then my 449. Ryan used the 1 7/8" into 2" Step header with 3.5" collector, i have not try any other size yet, will be cool to find extra hp/trq.i want to try a3 step w/2 inch to 2 1/8 to 2 1/4 with a 4 inch merge colector, just don't know how tight is going to be on my 65...
Re: Indy 360-1 Header Tube size [Re: FIREGUY12] #447976
08/24/09 11:36 AM
08/24/09 11:36 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
It would be easier to make suggestion if you had an RPM range but, since
the engine is under 400" and guessing peak power at 7300.........
1.875" x 25.5" w/3.5" x 15" collector
OR
1.875" x 13" stepped to 2.0" x 13" w/3.5" x 15" collector
I can give you specs for 3-step too.
Re: Indy 360-1 Header Tube size [Re: S/ST 3040] #447977
08/24/09 12:01 PM
08/24/09 12:01 PM
HOUSTON,TEXAS
HOUSTON,TEXAS
I think the engine will peak out at around 7500-7600. Thanks for the information.
Re: Indy 360-1 Header Tube size [Re: FIREGUY12] #447978
08/24/09 04:36 PM
08/24/09 04:36 PM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
Warren, nice to see your still plugging away at it. Hope to see you out soon. BTW, straight 1 7/8" gets my vote b/c of the powerslide.
Re: Indy 360-1 Header Tube size [Re: SuperStocker] #447979
08/24/09 08:32 PM
08/24/09 08:32 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I think the flanges that Indy sells are for a 1-7/8 tube. Thats what Ryan told me over the phone. I am building 1-7/8 X 2 X 2-1/8 with a merged collector with a 2-1/2" pinch back up to 3-1/2" secondary exhaust. My Primaries will be super long since I make them to fit the car.
6400 RPM 501 Cubic Inch Indy 360-1 245CNC 48Deg Hyd Roller cam.
SRT DEMON ONE SEAT
Re: Indy 360-1 Header Tube size [Re: Ron Silva] #447980
08/24/09 08:40 PM
08/24/09 08:40 PM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
501".. Ron.....Why such a small, small block? LOL!!!
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: Indy 360-1 Header Tube size [Re: PUNK] #447981
08/24/09 09:05 PM
08/24/09 09:05 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I want to be able to rebuild it once or twice.
My vote is 1-7/8 all the way as said above. Smaller tubes will NEVER hurt you as much as some people think and if you have a powerglide the Tq would be better. The shortest tube should be 34" on an automatic car. Equal length is overrated. I don't even try.
SRT DEMON ONE SEAT
Re: Indy 360-1 Header Tube size [Re: Ron Silva] #447982
08/24/09 10:36 PM
08/24/09 10:36 PM
Mcallen, TX
Mcallen, TX
THAT IS JUST BEAUTIFULL ...dragrcr97
Re: Indy 360-1 Header Tube size [Re: SB449VALIANT] #447983
08/25/09 07:55 AM
08/25/09 07:55 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
Don't mean to change the topic but how much power or how fast is this 501 SB? Why not a solid roller in a stout motor?
Re: Indy 360-1 Header Tube size [Re: Otherlane] #447984
08/25/09 09:45 AM
08/25/09 09:45 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
dragrcr97, when are we going to hear the details of that engine?? Certainly sounds very interesting!! Are those heads going to be able to support 501"??
Re: Indy 360-1 Header Tube size [Re: Ron Silva] #447985
08/25/09 11:58 AM
08/25/09 11:58 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
only way to top that would be if it was blown
