Spraying Organosol Black #447420
08/23/09 06:55 PM
08/23/09 06:55 PM
S.E. Florida, USA
rrunner Offline OP
rrunner  Offline OP
S.E. Florida, USA
Looking for tips on spraying organosol black. Thanks
Re: Spraying Organosol Black [Re: rrunner] #447421
08/23/09 06:59 PM
08/23/09 06:59 PM
Kirkland, Washington
Pacnorthcuda Offline
Practice first. One thing I notice is that it changes appearance/texture with each coat, and its very dependant on coat thickness. You want the game-plan decided by this practice before you paint the item. 2-3 coats will do, but you want to decide 2 OR 3 before hand.
I prefer pretty wet coats myself--almost on the heavy side, but your practice session may give you different results.
Re: Spraying Organosol Black [Re: Pacnorthcuda] #447422
08/23/09 07:05 PM
08/23/09 07:05 PM
S.E. Florida, USA
rrunner Offline OP
rrunner  Offline OP
S.E. Florida, USA
Yes, I will be practicing for sure. I am looking for info on gun set up, mostly what tip size is good.
Re: Spraying Organosol Black [Re: rrunner] #447423
08/23/09 07:14 PM
08/23/09 07:14 PM
I used a 1.6 in a DeVilbiss gun (PPG paint) and it was fine. I don't remember specific PSI other than it wasn't abnormal so probably 40-45 at the gun
