pushrod oiling holes? #446699
08/23/09 02:29 AM
08/23/09 02:29 AM
KY
juicedcuda Offline OP
KY
I noticed that the old pushrods from my motor have holes in them for oiling. They are the INDY pushrods, I was running -1's and INDY rockers. I am now running a solid roller with 892 lifters and T&D shaft mount rockers. My question is when I go to order the new pushrods, do I need them to put holes in them again?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: pushrod oiling holes? [Re: juicedcuda] #446700
08/23/09 09:52 AM
08/23/09 09:52 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Not if you arent using push rod oiling... doesnt
really matter
Re: pushrod oiling holes? [Re: MR_P_BODY] #446701
08/23/09 02:07 PM
08/23/09 02:07 PM
KY
KY
What would keep the rollers on the lifters oiled, which I am assuming is the holes is the cups in the lifters?
Re: pushrod oiling holes? [Re: juicedcuda] #446702
08/23/09 02:34 PM
08/23/09 02:34 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Hello Neighbor
The shaft mounted T&D rockers should oil through the factory passages in the block.
What lifters do you have?
The only way these would even work if you had the special lifters (AMC style) that leads to push rod oiling.
I plan to run pushrod oiling i conjunction with stock Hemi oiling on my new Hemi. The lifters I have will allow oil to travel through the push rods to keep the push rod tips and cups nice and cool. But at this point the holes will be very small. Were looking at .020-.030 restricter.
Re: pushrod oiling holes? [Re: Bob_Coomer] #446703
08/23/09 03:54 PM
08/23/09 03:54 PM
KY
KY
I am using the comp endure x 892 lifters. I just didn't know how the cups on the lifters and the wheels got lubricated without using pushrod oiling but I was unaware the pushrod oiling was for oiling the topside of the pushrods.
Re: pushrod oiling holes? [Re: juicedcuda] #446704
08/23/09 06:57 PM
08/23/09 06:57 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Oil splash, thats why we used to break old flat tappet cams in by reving the engine up, to permote good oil splash and to get the lifters turning in the bores.
Its also isnt a good idea to let new engines idle at low rpm's for extended amount of times.
Re: pushrod oiling holes? [Re: juicedcuda] #446705
08/23/09 08:19 PM
08/23/09 08:19 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I used the AMC style 848 comp endure-x in my hemi and my friends big wedge.Only sent oil up the exhaust pushrods on the hemi and all 16 on the wedge.The wedge has more problems with burnt cups,so to add pushrod oiling is a good thing.I have 2 years and over 8,000 miles on these lifters.I will also tell you that a loss of 15 lbs of oil pressure was present with both engines,but well worth the insurance with EDM lifters. The lifters get oiled through the lifter galley.You can see 2 oil orifices if you look at the lifter or go to the comp website for pic's.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: pushrod oiling holes? [Re: hemi-itis] #446706
08/23/09 09:04 PM
08/23/09 09:04 PM
KY
KY
So if I wanted to use the pushrod oiling, I would just need to order the pushrods with holes?
Re: pushrod oiling holes? [Re: juicedcuda] #446707
08/23/09 11:04 PM
08/23/09 11:04 PM
hemi-itis Offline
hemi-itis  Offline
Yes,speak to Terry at Manton about using restrictors in the holes if your using a stock oil pump.
Re: pushrod oiling holes? [Re: hemi-itis] #446708
08/24/09 01:41 AM
08/24/09 01:41 AM
KY
KY
Will do. Thanks for the help guys.
