TIRE FITTING #445294
08/21/09 05:57 PM
08/21/09 05:57 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Will 235 75 15's fit well on Dakota 15x8 rims? I'm concerned about squeezing the tread pattern w/that wide a wheel.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: TIRE FITTING [Re: Magnumguy] #445295
08/21/09 06:26 PM
08/21/09 06:26 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
They will fit.
The tire installer may have to use a bead blaster to get the bead to pop onto the wide rim,IMO.
The sidewalls will be out a bit more than the tread.
I know that the oddball 2556515 tires are getting tougher to get.I work at a tire shop and run into this all the time.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: TIRE FITTING [Re: Magnumguy] #445296
08/22/09 09:09 AM
08/22/09 09:09 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Looked ok wore ok for me.
