indy rear main seal replacement for hemi ? #444906
08/21/09 08:15 AM
08/21/09 08:15 AM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline OP
VanishPt  Offline OP
V
I have a Indy rear main seal that seems to be starting to drip. Anything difficult or trick to replacing the seal ?
Re: indy rear main seal replacement for hemi ? [Re: VanishPt] #444907
08/21/09 10:46 AM
08/21/09 10:46 AM
Near Indy
slowpoke Offline
slowpoke  Offline
Near Indy
Just curious, is this an Indy built motor/shortblock that is leaking at the rear main or simply an "Indy" brand seal you've used in your motor that is leaking (non Indy built)?
Re: indy rear main seal replacement for hemi ? [Re: slowpoke] #444908
08/21/09 02:36 PM
08/21/09 02:36 PM
V
VanishPt Offline OP
VanishPt  Offline OP
V
this is an Indy brand. Motor has about 30K miles on it.
Re: indy rear main seal replacement for hemi ? [Re: VanishPt] #444909
08/22/09 07:43 AM
08/22/09 07:43 AM
V
VanishPt Offline OP
VanishPt  Offline OP
V
