Page 1 of 6 1 2 3 4 5 6
off idle stumble with Edelbrock 750 -UPDATE -FIXED #443767
08/19/09 11:20 PM
08/19/09 11:20 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
I've recently replaced the intake and carb on my 1970 440 and have an issue I'd like some real world direction on before I tear into the carb.
I had an Edelbrock performer RPM intake and a Holley 850 Double pumper on the car previously. The car ran well, and was great leaving a stoplight either in my neighborhood at low speeds or when moving off the line a little quicker This combo was really too tall for the stock hood and I wanted a more stock appearing engine compartment.
I swaped in a 1971 square bore iron 440 intake and an Edelbrock #1411 750 cfm vac secondary carb. I'm OK with the overall performance of this combo as this car is a driver and I'm willing to trade maximum performance for street manners.
The issue I have is an off idle stumble at light throttle; I need to give the car much more throttle to leave a stop smoothly than I did with the Holley. If I rev it up and slip the clutch more, it works great, but at light throttle it stumbles/bogs.
I've been reading on the internet and this seems to be a fairly common issue with this carb on larger displacement engines.
Has anyone had real experience with these, I just wanted a reality check before I go tearing into this carb and spend a bunch of money and time for marginal results!
Thanks!
Scott
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: 70Sbird] #443768
08/19/09 11:27 PM
08/19/09 11:27 PM
Kansas
racincuda Offline
racincuda  Offline
Kansas
Try a different hole for the accelerator pump rod, if it gets better then try the next hole, if not quite ther then bend that little connecting link a little bit and I bet your problem is solved
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: racincuda] #443769
08/19/09 11:34 PM
08/19/09 11:34 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Not that it can't work, but you are in a long list of guys that have faught with the Eddy 750 off-idle stumble. Do a search on it, you'll be amazed. I tried every setting and rod / jet combo immaginable. Tried two different carbs, same issue with both. Went to a Holley 750, Sooooo much better.
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: racincuda] #443770
08/19/09 11:37 PM
08/19/09 11:37 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
Depending on your engine componits, your engine may require more fuel...so you may have to rejet it.
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: 70Sbird] #443771
08/19/09 11:44 PM
08/19/09 11:44 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Is it a new carb?
Might just be a weak accel pump not shootng out fuel right away.
Look down in the carb and move the throttle, see if fuel comes out right away.
I want my fair share
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: racincuda] #443772
08/19/09 11:45 PM
08/19/09 11:45 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
pump rod is in the closest hole to the pivot(most sroke) I'm thinking of going to the .043 shooters vs the .035 that is on there now, I've also been told to drill out the idle tubes a few thousands of an inch, and to get the tuning (rods and springs) kit. I was just wondering if anyone has tried this? I don't want to spend $100 on carb tuning accessories for trial and error.
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: 70Sbird] #443773
08/19/09 11:50 PM
08/19/09 11:50 PM
SomeCarGuy Offline
SomeCarGuy  Offline
Put the money in another carb. A Holley or any of the other Eddy offerings is going to work out better.
You can take this current carb apart and look for crap left in it, some people have said they had junk in their brand new carb.
You might need stiffer springs, it may be sucking the rods down and blocking the jets for a sec. Would be nice to try somebody elses springs in it before you drop the money on the strip kit.
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: SomeCarGuy] #443774
08/19/09 11:55 PM
08/19/09 11:55 PM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
I have been through this personally with a couple of Eddy 750's and I have a solution that Does Work!
1) Verify that your floats are set properly
2) Try different springs for a quicker opening of the needle.
3) Verify that your accelerator/plunger is good(replace if any doubt)
4) Adjust the linkage that operates the accelerator; There's 3 settings, I believe the arm should be in the top hole.
5) Finally, the thing that most guys won't try: Remove the Primary Squirters and drill them out very, very slightly(get some tiny, tiny drill bits). Don't be afraid to try it.
The last one is what did it for me.
Let us know how you make out.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: Hoof Hearted] #443775
08/19/09 11:59 PM
08/19/09 11:59 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
2) Verify that your accelerator/plunger is good(replace if any doubt)
3) Adjust the linkage that operates the accelerator; There's 3 settings, I believe the arm should be in the top hole.
4) Finally, the thing that most guys won't try: Remove the Primary Squirters and drill them out very, very slightly(get some tiny, tiny drill bits).
so you're suggesting drilling out the accelerator pump shooters slightly?
I can do that fairly easily! the kit they sell has three sizes and maxes out at .043" compared to the .035 on there now
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: 70Sbird] #443776
08/20/09 12:11 AM
08/20/09 12:11 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Be EXTRA sure you have tried EVERYTHING else before you drill or modify ANYTHING. The fastest way to start chasing your tail before you find the real problem is to start modifying componants.
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: 70Sbird] #443777
08/20/09 12:14 AM
08/20/09 12:14 AM
S.E. Conn
S.E. Conn
yep. Start small, it don't take much out initially and be sure to follow/drill straight thru. (No coke bottleing at the end)
Instantly noticable improvement.
You made it clear your wishes were to stay stock looking and have more clearance. You Were Clear on this point. Yet the usual Anti-Eddy/holley-rules crowd had to ignore your preferences.
I love Moparts, don't you?
2005 300C Hemi
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: Hoof Hearted] #443778
08/20/09 12:30 AM
08/20/09 12:30 AM
SomeCarGuy Offline
SomeCarGuy  Offline
If he wants it to look stock he needs to find a Carter AVS or second choice would be the Eddy AVS.
What was that about ignoring his wishes of looking stock???
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: SomeCarGuy] #443779
08/20/09 08:02 AM
08/20/09 08:02 AM
Az
Crizila Offline
Crizila  Offline
Az
Get the tuning kit for that carb and follow the booklet instructions that came with that carb and you should be able to easily fix your off idle stumble problem. These are some of the easiest carbs I know of to tune, and the booklet makes it a no brainer. Edelbrock did their homework. For your application you shouldn't have to modify anything on the carb to get it to work well. Per many good comments on this thread, make sure the carb is healthy to start with - good pump diaphram, floats set properly, etc, then just make changes to the rods, springs, jets, pump rod, per the booklet ( calibration reference chart )and you should be good to go.
Fastest 300
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: Crizila] #443780
08/20/09 09:06 AM
08/20/09 09:06 AM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
Thanks for the feedback,
I guess I should clarify, I want a stock appearing engine compartment with the stock air cleaner and coil location, those were not options when I had a dual inlet holley and tall intake.
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: 70Sbird] #443781
08/20/09 09:37 AM
08/20/09 09:37 AM
Az
Crizila Offline
Crizila  Offline
Az
"Pretty, but can it fight." Stock appearing ? - "CAT" on the side of your battery aint workin.
Fastest 300
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: Crizila] #443782
08/20/09 09:50 AM
08/20/09 09:50 AM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
You have to understand this car is a driver that is still in the process of becoming a complete car from the abandon project in boxes and pieces that it was when I purchased it a few years ago, I'm just trying to do this one step at a time, and I already had the battery!
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: 70Sbird] #443783
08/20/09 10:06 AM
08/20/09 10:06 AM
Az
Crizila Offline
Crizila  Offline
Az
I'm just kidding. Really looks great. I wish my drivers looked that good.
Fastest 300
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: Crizila] #443784
08/20/09 10:17 AM
08/20/09 10:17 AM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
Thanks,
I looks better in pictures than it does up close. If I was worried about perfection I'd just build a big model and keep it on shelf, this car gets driven! Thus my desire for a smooth operating carb!
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: 70Sbird] #443785
08/20/09 10:56 AM
08/20/09 10:56 AM
Wethersfield,CT
Ray440 Offline
Ray440  Offline
Wethersfield,CT
Has anyone tried this before? Below the accelerator discharge squirter there is a small weight and a check ball. Buddy of mine had removed the weight and his stumble is gone. Leave the check ball in.
1969 Plymouth Road Runner 440 auto
2017 Ram 1500 Quad Cab 5.7 Hemi
Re: off idle stumble with Edelbrock 750 - suggestions? [Re: Ray440] #443786
08/20/09 02:43 PM
08/20/09 02:43 PM
That would make sense as the weight would take up space & interfere w the flow, then if you dial in your shooter nozzle dia
