Re: mancini frame connectors.....help please
[Re: Zapp]
#443397
08/19/09 10:17 PM
08/19/09 10:17 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
There's a ton of info on this subject in the archives. Search and you will find....
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Zapp]
#443401
08/20/09 03:44 PM
08/20/09 03:44 PM
Posts: 89 oregon
ramcharger1964
oregon
Just line it up with the orig frame on the other side of the crossmember. If you are using a wire feed just split the difference on both sides an dleave an 1/8th inch gap on each side - easy to fill. Then go in with a good hot stick weld (or wire)to get some good penetration!!!!!!
Hell B!tch Racing Co.
