Thanks for your interest guys.
RemCharger, what kinda tires are on that 12.40 ride?
67 Charger, I like your car too
. I am not sure if a 10" con. will help because the local track´s surface is a handful for the current combo. I have been experimenting with different weights in the rear this summer. This car likes to be heavy in the back.
470bee here is my combo. It is a testament to my eccentricity:
-Muscle Motors 451 stroker kit (440 crank, Ross pistons, Cat H-beam rods)
-Childs & Albert file to fit top rings. Hastings oil rings
-Stock Edelbrock heads.
-10,69:1 CR
-Competition Cams flat tappet, .585" lift. 255 degrees @ .050"
-Crane Ductile Iron rockerarms
-Isky springs, 135 pounds seat pressure
-Carter mechanical fuel pump
-Edelbrock TM6 manifold
-Holley 850 HP carb.
-MSD Pro Billet distributor međ MSD 6AL, MSD Pro Power coil
-Fluidampr
-TTI headers
- 2 1/2" exhaust with Straightline 2 1/2" mufflers
-Mopar Performance HV Oil pump with 1/2" pick up
-Mopar Performance windage tray w. Moroso deep sump oil pan.
-MP Aluminum water pump
Trans:
-727with 11" TCI converter 2800-3000 stall
-B&M Transpack
-B%M flexplate
-Locar kick down
Rear:
-8 3/4 Powerlok SG with a 4.10:1 ratio.
-Stock shocks and original HD springs
Front:
-6 cyl torsion bars
-Stock, well worn shocks
Tires rear:
Firestone Firehawk true radials, 15 x 10"
