More R block questions #442695
08/19/09 10:27 AM
08/19/09 10:27 AM
Lubbock,TX
DavidDean Offline OP
Lubbock,TX
I'm looking at some R block stuff.The casting # is 4532907.The information I have says its a 48* siamese block w/9.2 deck hite.Were they ever made in a 9.0 deck? I can use the 9.2 deck but not 9.0 deck.Thanks
Re: More R block questions [Re: DavidDean] #442696
08/19/09 01:12 PM
08/19/09 01:12 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Without looking up casting #'s, real quick, just ask them if it has a machined oil filter boss on it to accept an oil filter, if it does it is not a 9.0" deck. 9.0 Decks will have a blank unmachined boss.
Also most 9.20's have motor mounts, 9.0's don't. Real quick simple way to tell a 9.2 VS a 9.0 visually
Re: More R block questions [Re: DavidDean] #442697
08/19/09 02:10 PM
08/19/09 02:10 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
That casting was machined 5 different ways, three PNs were 9" and two PNs were 9.20", so just use Ryans ID tips and you should be able to figure it out.
Re: More R block questions [Re: ZIPPY] #442698
08/19/09 03:05 PM
08/19/09 03:05 PM
Lubbock,TX
Lubbock,TX
Thanks fellas, I'm thinking it is a 9.00 deck.I understand it has no oil filter mount.
Re: More R block questions [Re: DavidDean] #442699
08/19/09 03:49 PM
08/19/09 03:49 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
No filter boss machined is 9.00 deck, & it will not have motor mounts either. I've only seen 1 9.0" R3 with both motor mounts, the Aluminum cap PS truck 9.0 R3's had ONE motor mount per side... Those blocks (PS truck) also have 7/16" head bolt holes.
Re: More R block questions [Re: RyanJ] #442700
08/19/09 05:05 PM
08/19/09 05:05 PM
Lubbock,TX
Lubbock,TX
Thanks, Ryan your exactly right.After looking at the pictures it doesn't have the motor mount bosses.
