demon carb problem STRIPED SQUITER SCREW HELP #442186
08/18/09 05:24 PM
08/18/09 05:24 PM
IL . usa
cjs69mope Offline OP
IL . usa
Hi does anyone know of a easy way to repair a striped out accelerator pump squirter knozzel hold down screw ?
it is a very odd size 12-28 inch , checked helicoil web sight they do not have a listing for a repair of that size .
has anybody had this happen to them what should i do ?
any help would be great thanks in advance moparts ! cjs69mope@sbcglobal.net
1969 Dodge Charger 1969 Dodge Superbee
Re: demon carb problem STRIPED SQUITER SCREW HELP [Re: cjs69mope] #442187
08/18/09 05:58 PM
08/18/09 05:58 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
here you go. I have one of these. search for part 34620
http://www.allfasteners.com/Recoil-Thread-Repair-Kit-34620-12-28-4010pcs41-403462041_p_2308.htm
Local carb shop , AED< in Richmond Va uses a 12-24. says it is close enough. The screw feels a little tight going in , but the 12-24 does work.
Re: demon carb problem STRIPED SQUITER SCREW HELP [Re: cjs69mope] #442188
08/18/09 10:11 PM
08/18/09 10:11 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
The link below is to BLP, which is Bo Laws Carbs. I just used one of their kits to repair a stripped squirter screw on a Ford tri-power carb. Not easy - best done on a drill press or a verticle mill to get hole reamed centered and straight. Hole is reamed out and an insert is pressed/locktited in that has threads and the fuel slots. Site has a lot of neat stuff.
http://www.blp.com/frmCatalog.htm
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: demon carb problem STRIPED SQUITER SCREW HELP [Re: Evil Spirit] #442189
08/19/09 02:18 PM
08/19/09 02:18 PM
IL . usa
IL . usa
thanks for the info great help !
