Holley Jets for E-85 #442163
08/18/09 04:53 PM
08/18/09 04:53 PM
charlotte nc
jimmysarrow Offline OP
charlotte nc
Does anyone know the correct drill bits to drill out holley jets for # 102 thru 110. I have a chart but it does not match a fraction size drill bits or number or letter size drill bits.I am testing a E_-85 carb thursday and need the bigger jets
Re: Holley Jets for E-85 [Re: jimmysarrow] #442164
08/18/09 09:24 PM
08/18/09 09:24 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
JET Size
101 0.126 (1/8 .125, 3.20mm .126)
102 0.128 (#30 .1285)
103 0.130 (3.30mm .1299)
104 0.134 (3.40mm .1339)
105 0.137 (3.50mm .1378)
106 0.141 (#28 .1405, 9/64 .1406)
107 0.145 (#27 .144, 3.70mm .1457)
108 0.147 (#26 .147)
109 0.150 (#25 .1495, 3.80mm .1496)
110 0.156 (5/32 .1562)
remember you want 27% more volume NOT a 27% bigger hole.
Re: Holley Jets for E-85 [Re: TS3303] #442165
08/18/09 10:07 PM
08/18/09 10:07 PM
charlotte nc
charlotte nc
Thanks for the chart , but if you have a 105 jet dont you need to drill a .137 hole , there is my question ,what size drill bit is a .137 , a fraction bit , number bit , or a letter bit ?
Re: Holley Jets for E-85 [Re: jimmysarrow] #442166
08/18/09 10:34 PM
08/18/09 10:34 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
#29 is .136 3.5mm is .138
Re: Holley Jets for E-85 [Re: TS3303] #442167
08/19/09 08:35 PM
08/19/09 08:35 PM
charlotte nc
charlotte nc
Thanks for the info. So holley made this with special drill sizes , I will just have to find something close to the size as per you example.
Re: Holley Jets for E-85 [Re: jimmysarrow] #442168
08/19/09 09:12 PM
08/19/09 09:12 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I think he is looking to convert the decimal into a fraction .128 is 128/1000 which in its lowest terms is 16/25 but at the same time.... .126 is 63/500
Re: Holley Jets for E-85 [Re: joshking440] #442169
08/19/09 09:33 PM
08/19/09 09:33 PM
charlotte nc
charlotte nc
no , what I am trying to figure out is what drill bit sizes to use to make the 101 thru 110 jets using smaller jets.
Re: Holley Jets for E-85 [Re: jimmysarrow] #442170
08/19/09 09:42 PM
08/19/09 09:42 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Well combined with the previous post above I think we accomplished that Jimmy... even though the sizes seem unorthodox.
JET Size......drill bit size
101 0.126....63/500
102 0.128...16/125
103 0.130...13/100
104 0.134...67/500
105 0.137...137/1000
106 0.141...141/1000
107 0.145....29/200
108 0.147....147/1000
109 0.150.....3/20
110 0.156......39/250
Re: Holley Jets for E-85 [Re: jimmysarrow] #442171
08/19/09 09:43 PM
08/19/09 09:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Have you changed anything else on the carb besides
going bigger on the jets... not quite that simple
Re: Holley Jets for E-85 [Re: jimmysarrow] #442172
08/19/09 09:51 PM
08/19/09 09:51 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
I assumed by that statement the carb had already been converted.
Jet orifaces are sized for volume not by a drill index. + or - .001" will have less affect on volume than specific gravity, etc. you need to sneak up on the final hole size to avoid ridges and cutter marks on the bore as they will affect flow.
Re: Holley Jets for E-85 [Re: TS3303] #442173
08/19/09 09:52 PM
08/19/09 09:52 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Raff....you will know better than me I think, but should he be looking more at reamers than drill bits???
Re: Holley Jets for E-85 [Re: joshking440] #442174
08/19/09 09:55 PM
08/19/09 09:55 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
101 0.126....63/500
102 0.128...16/125
103 0.130...13/100
104 0.134...67/500
107 0.145....29/200
109 0.150.....3/20
were do you buy that drill index at?
Re: Holley Jets for E-85 [Re: TS3303] #442175
08/19/09 09:59 PM
08/19/09 09:59 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I was searchin in the special deal section and cant find a thing......
I know you can get reamers in the crazy sizes
Re: Holley Jets for E-85 [Re: MR_P_BODY] #442176
08/19/09 11:41 PM
08/19/09 11:41 PM
charlotte nc
charlotte nc
yes the carb has been changed to E-85 by Heath Daniels @ race on E-85. Just trying to have spare parts to change jets if needed & 100 - 110 jets are not in stock at most speed shops and @ $7.00 a set of 2 , thought I might be able to fix the jets myself with drill bits.
Re: Holley Jets for E-85 [Re: jimmysarrow] #442177
08/20/09 06:59 PM
08/20/09 06:59 PM
NC
440Jim Offline
440Jim  Offline
NC
You can get "close" with drilling out jets. But unless they are flowed, you can be a couple "sizes" off in flow. The length of the hole and the chamfer (bevel) and both the entrance and the exit will change the flow of the jet.
IMO, at those large sizes, drilling is OK for getting it close, but then you will need flowed jets to fine tune it.
Re: Holley Jets for E-85 [Re: 440Jim] #442178
08/20/09 11:26 PM
08/20/09 11:26 PM
charlotte nc
charlotte nc
Thanks for the help, weather (rain) killed testing tonight , try again next week. Looking forward to trying this e-85 fuel. Got to figure it out before the Mopar Bristol Race Labor Day.
