340 Engine needs thicker head gasket
#441761
08/18/09 06:56 AM
08/18/09 06:56 AM
Posts: 589 Waynesboro, PA
cuda_tim
Waynesboro, PA
Guys!
I have a 340 engine that appears to require thicker head gaskets than the 0.039 (compressed thickness) of the Fel-Pro's (which I've always used with great success).
I inquired about getting some 0.055 (also compressed thickness) gaskets from Cometic, but I'm concerned with the 50 RA finish (along with the flatness requirement) that is needed to insure they seal properly.
Question: I was considering using a 0.016 steel shim with the composite Fel-Pro's. Is this a viable option? How long would this last?
Anybody?
Thanks!
Tim...
"Robots building robots.... now that's just stupid!" - Will Smith in the movie "I, Robot".
'71 Demon (340/727)/'69 Charger (383/727)/'65 Barracuda (273-2V/904)/'66 Coronet (340/727)/'86 Dodge Aries (2.5L)/'78 Dodge Aspen (318-2V/904)
Re: 340 Engine needs thicker head gasket
[Re: cuda_tim]
#441762
08/18/09 08:13 AM
08/18/09 08:13 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
fel pro has a .053 head gasket... mr gasket has a .028 head gasket....pn 1121
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#441763
08/18/09 09:11 AM
08/18/09 09:11 AM
RapidRobert
I have a set of fel pro 8553pt? blue ones that are I believe .054"
[Re: RapidRobert]
#441764
08/18/09 10:26 AM
08/18/09 10:26 AM
Posts: 4,884 Michigan
MNobody
I'm just guessing but i bet the 53 at the end of the part number means .053 thick but i've been known to be wrong
[Re: cuda_tim]
#441767
08/18/09 03:07 PM
08/18/09 03:07 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
whatever ones that came in my 360's felpro engine teardown kit (I think it's the 8553PT's) were .054".
[Re: patrick]
#441768
08/18/09 03:10 PM
08/18/09 03:10 PM
RapidRobert
I miked my new 8553pt's @ .054" and head gaskets only crush a couple of thou
