RPM Redline for stock 383/4bbl #441305
08/17/09 09:46 PM
08/17/09 09:46 PM
Blanchard, OK
Real-Fury Offline OP
Blanchard, OK
Actually there are several questions to this post.
Since this is my 1st Mopar with a 383/4bbl to be exact (no tach yet) in a stock 64 Fury I'm wondering what to expect for a safe or typical RPM redline. 5000 was it for stock small block chevy's I grew up with and I'm figuring 5000 is about it for a stock 383 as well. Is this right?
I was thinking of changing the 3.23 rearend for a lower ratio to add some zip but after reading several threads on this forum I think I'm going about it all wrong. Looks like I should be trying to increase the HP and Torq before messing with the rearend ratios.
Any suggestions for bolt on items that will increase the power and what kind of increases can I expect. I don't want to break this engine either as it is the original to the car, but I also starting to question the real value of that too. Seems nobody wants stock and 440/426's seem to be the big draw on these cars.
Thanks,
Butch
Re: RPM Redline for stock 383/4bbl [Re: Real-Fury] #441306
08/17/09 10:03 PM
08/17/09 10:03 PM
florida
74fldart Offline
74fldart  Offline
florida
the stock 383 cam is all done by 5500. the manifold wont do anything above that either . you might get a little more rpm out of it but power will be dropping. change the cam and intake and put on headers and good exhaust and youll see the redline go up. maybe rejet the carb too. as far as the gearing goes, the 323 is not really a performance ratio so if it was me i would go to at least 355s. you could modify the engine 1st then if your happy with it leave the gears alone.
if you pick the right cam, intake, headers, you could see a 30 or 40 hp increase.
Re: RPM Redline for stock 383/4bbl [Re: Real-Fury] #441307
08/17/09 10:10 PM
08/17/09 10:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Some of my stock 383s were stronger than others, sometimes by a margin large enough to be baffling.
Usually they run out of pull around 5200-5500 RPM.
For a street car with 3.23s, I'd tweak it for torque.
A really sharp tuneup, good dual exhaust with H or X pipe, better ignition, Eddy AVS-style carb, and 1.6 rockers & better valve springs would be my first mods.
After that maybe a more modern cam profile and either HP exhaust manifolds or smallish headers, but it won't look so stock anymore.
If you plan on enjoying the power, the 10" brakes aren't really up to the task, and I'd put some swaybars on it.
Re: RPM Redline for stock 383/4bbl [Re: Real-Fury] #441308
08/17/09 10:23 PM
08/17/09 10:23 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Assuming that this is an original untouched engine valve spring tension could be anything from good to poor in which case anything from 5000- 5800 rpm is possible. Early heads like yours have some serious drawbacks. First of all if you intend to put any real mileage on it,
hardened exhaust valve seats should be installed. While you're at it you may as well do a proper three angle valve job and take a .010-.020 truing cut on the block surface of the heads. A bowl port would help a lot as well. The problem with all this is that the cost is such especially after probably having to repair/replace worn guides that you could buy new aluminum heads that flow better for very little more money.
If you want to roll the dice on how long the valve seats will hold up, buy a good set of headers and an RPM intake and top it with a 3310 Holley [750 cfm, vac. sec. ]. Two safe cam choices for a basically stock engine would be the 272 MP purple shaft or a Comp XE268H along with fresh valve springs. You SHOULD always check piston to valve clearance and retainer to guide clearance as well as coil bind with any cam change, but these cams are mild enough that you probably won't have any problems. These cams will work with your stock torque converter although they may pull a little in gear at a stop. If you plan to hammer it a lot a Hemi pan and pickup would be a good idea as well.
If you can afford it the best solution is to yank the original engine and store it and build a good 451 low deck. It will look like a 383, but run much better.
You have a lot of choices, it just comes down to how much speed you want and how many cubic dollars you have to spend.
Re: RPM Redline for stock 383/4bbl [Re: Real-Fury] #441309
08/17/09 11:43 PM
08/17/09 11:43 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Headers and intake I would do either way. But cam and rear end gears have to work together. If you go with numerically higher rear gears say 3.73 or 3.91 or 4.10 you can get away with a lot more cam than with your stock 3.23's. But it all depends on what you want out of the car(and how high of a cruising rpm on the highway you can stand!).
But I agree w/ the above post, heads at this age often need help. If your valve springs are old and weak your engine may not even rev above 4500-5000rpm.
Re: RPM Redline for stock 383/4bbl [Re: Real-Fury] #441310
08/18/09 12:46 AM
08/18/09 12:46 AM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
What cam do you even have? If it is a stock then a cam change is pretty a pretty good for a street car.
A gear change will only get the car to shift gears sooner at the track and not really do anything for you if you don't run a large cam.
It may feel faster if that is what you want, but members have posted in the past that a gear change resulted in less than a tenth change in ET for a mild combo. We are talking a 3.23 to a 3.91, not really worth it unless you are going to get real agressive on a cam. Then the gear gets more important.
If you are asking what the bottom end will take, this ain't no Chevy. It should be good to 6000 unless it is worn out, then all bets are off. The cam/springs will limit how high you can turn it though.
I want my fair share
Re: RPM Redline for stock 383/4bbl [Re: Real-Fury] #441311
08/18/09 09:16 AM
08/18/09 09:16 AM
Blanchard, OK
Blanchard, OK
Great responses and very helpful. This is supposed to be a bone stock 383 and I have no reason to doubt it. Bought it represented to have 39000 miles which was on the Title (I know big deal) but every part of the car looks it. Engine revs surprisingly quick up and down which also supports the low mileage claim. But, regardless, its 45 years old and the motor isn't a spring chicken anymore. Absolutely stock under the hood including the foil heat barrier underneath the intake.
This will always be a street cruiser and not a race car while I own it but like everyone else I like to punch it and feel the power. I expect one of these days I'll be locking horns with one of the little imports on the street and would like to have a presentable showing for the old gal.
But, the old saw seems to be just as true today as it was 40 years ago. "Speed cost money--how fast do you wanna go?"
Love to put a stroker, upgraded 4 speed A/T trans and converter with a 65-67 suregrip and higher gears, but that's another $15-20k by the time the brakes, suspension and other items are upgraded to match the power. Not sure I can justify that as I don't have that many years of driving this type car left in me and what I see the modified 64's bringing (or not bringing) these days is pretty sad. Guys are lucky to get half their money back.
So, I GUess I'll take this a little at a time and see where it leads me. I'll change out the intake, carb, maybe headers or HP manifolds (by the way are these manifolds almost as good as headers) and definitely some suspension updates. I sure don't remember the 60's cars driving so loose and sloppy. Kinda like driving a boat. I've added HD shocks so hopefully some swaybars and better tires will help.
I just know one thing leads to another and it's hard to just do one upgrade without wanting or having to do several others. So, I guess we're off to see the wizard!
Any other recommendations are greatly appreciated especially on which mods to do 1st.
Butch
Re: RPM Redline for stock 383/4bbl [Re: Real-Fury] #441312
08/18/09 11:00 AM
08/18/09 11:00 AM
I don't think they had the HP cam back in those days so that will be a real mild stick, going to limit what you can do.
The steering box may be in need of an adjustment.
Re: RPM Redline for stock 383/4bbl [Re: Real-Fury] #441313
08/18/09 12:31 PM
08/18/09 12:31 PM
NW of Indy
Thackdaddy Offline
Thackdaddy  Offline
NW of Indy
Some people still like the 383
Factory (dual plane) intake, 600 carb, 1 3/4 headers and 4:10 gears and redline at your best shift point, 5000-5500. Also, a Mopar electronic ignition and Blaster coil with a plug cap set at 40.
Re: RPM Redline for stock 383/4bbl [Re: Thackdaddy] #441314
08/18/09 12:56 PM
08/18/09 12:56 PM
Blanchard, OK
Blanchard, OK
I like the 383 if only because they used to beat me in the 60's when I was driving 327 chevy's.
I know the new rule is bigger is better but I can't believe a 383 can't be made to run strong and compete with the other big blocks without breaking the bank.
Butch
Re: RPM Redline for stock 383/4bbl [Re: Real-Fury] #441315
08/18/09 01:50 PM
08/18/09 01:50 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Regarding the lossey/gossey feel. The last thing you need is a strong engine [ ie. fast car ], and a worn out suspension and drum brakes. You can swap 70's-80's disk brakes on to the front and putting a '65 or newer rear end with flanged axles couldn't hurt although it's not really necessary at this time. Chances are good that the suspension bushings front and rear are shot from age. Bushings are relatively cheap and except for the LCA are easy to replace. Use either Moog heavy duty or poly. Personally I use poly for the UCA and the rear shackles and Moog for the LCA and strut rods and the front spring eyes. Strut rods bushings are very important since they maintain toe in. OK, the others do too, but they have a LOT to do with it. I guess I've spent enough of your money for now, good luck.
Re: RPM Redline for stock 383/4bbl [Re: 5spdcuda] #441316
08/18/09 02:37 PM
08/18/09 02:37 PM
IL
furious70 Offline
furious70  Offline
IL
http://www.moparmusclemagazine.com/techarticles/155_0209_resto/
is a great article showing step by step dyno work on a 383 from stock to more radical. Your stock heads aren't going to flow what 906's will but it's still an instructive article.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: RPM Redline for stock 383/4bbl [Re: Real-Fury] #441317
08/18/09 02:53 PM
08/18/09 02:53 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Call Summit order their 488 cam, find a used Holley SD intake, 750Dp carb, headers and an electronic ing kit. Set your timing at 38* at 2400 rpm, get a set of 3.91's and go have fun. Should spin to 5800 easy.
Coming soon!!!!
Re: RPM Redline for stock 383/4bbl [Re: Mr.Yuck] #441318
08/18/09 03:27 PM
08/18/09 03:27 PM
P
Paul_Fancsali Offline
P
If it is log manifold on those heads its all done by 5000 Period The HP will go 5800 but that was 68 up but power wise the 325 horse 383 was done power wise by 4500 and really doubt 325 horse 383 made anywhere near that number. The HP yes but the older ones in the 66 chargers etc were just not that fast
Re: RPM Redline for stock 383/4bbl [Re: 5spdcuda] #441319
08/18/09 07:06 PM
08/18/09 07:06 PM
Blanchard, OK
Blanchard, OK
Hey, don't worry about spending my money. The car needs to ride and handle right before adding more power. I wonder if replacing bushings is the way to go or should I just get a front end kit from Moog. I've seen prices on the front suspension kits and they run around $500-600. Don't know what the bushings only would cost.
Butch
Re: RPM Redline for stock 383/4bbl [Re: Mr.Yuck] #441320
08/18/09 07:56 PM
08/18/09 07:56 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
It may do it but it will be going nowhere fast. 5-5500 on that engine and its done..... Hell the magnums were done at 58-6000 tops stock. Yeah I know there will be some one that will say that they had one and it would twist 7000 and was till going. Wasn't gonna happen.
Re: RPM Redline for stock 383/4bbl [Re: MoparforLife] #441321
08/18/09 08:43 PM
08/18/09 08:43 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
around 5000...give or take a bit...I run a 498 stroker(440) with a real nasty cam and 5500 is My redline...give or take a bit....
Re: RPM Redline for stock 383/4bbl [Re: furious70] #441322
08/18/09 10:18 PM
08/18/09 10:18 PM
Blanchard, OK
Blanchard, OK
Thanks Furious70,
That's a very interesting article and some very impressive information. 450hp out of a 383 with just a change of cam, intake, carb and headers is pretty remarkable. That's the kind of performance I was hoping this engine could produce and is plenty of HP for me on the street. I hope the stock lower end can handle the increased power.
Butch
Re: RPM Redline for stock 383/4bbl [Re: Real-Fury] #441323
08/18/09 11:50 PM
08/18/09 11:50 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
You should have no problem with that bottom end. A new oil pump would be nice ,but usually not necessary .
Re: RPM Redline for stock 383/4bbl [Re: Real-Fury] #441324
08/19/09 08:48 PM
08/19/09 08:48 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Thanks Furious70,
Butch
Steve Dulcich, the writer for that article, really knows his stuff and his articles are very informative. The performance of that engine is impressive , but keep in mind that is a pretty hot cam in it. Low speed performance would probably be sluggish without at least a 3500 stall torque convertor. 4000+ would probably be best . From reading your post i get the impression you are wanting more of a cruiser and that cam may be a little more radical than you would like.
