How to install belt on 2004 Dodge Ram 1500? #440796
08/17/09 11:54 AM
08/17/09 11:54 AM
Houma, Louisiana
twister360 Offline OP
Houma, Louisiana
I need to replace the belt on my truck. What is the procedure to remove and reinstall? Engine is the Hemi. Thanks
Re: How to install belt on 2004 Dodge Ram 1500? [Re: twister360] #440797
08/17/09 12:22 PM
08/17/09 12:22 PM
Locomotion Offline
Locomotion  Offline
If it's anything like my Dakota or 3500 diesel, you'll need a breaker bar and socket to fit the idler/tensioner pulley bolt.
Pull it enough (the pully & arm it's on will move like a lever) to relieve the tension on the serpentine belt, slip it off and pull it out from around the pullies & fan. Do the opposite to reinstall. (Just have a diagragm handy of the belt routing.)
Re: How to install belt on 2004 Dodge Ram 1500? [Re: Locomotion] #440798
08/17/09 01:51 PM
08/17/09 01:51 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
A 3/8 drive fits into the square hole in the tensioner.
Take note of the belt routing, put a ratchet or breaker bar on the tensioner and relieve the tension to get the old off/put the new on.
Re: How to install belt on 2004 Dodge Ram 1500? [Re: ZIPPY] #440799
08/17/09 03:41 PM
08/17/09 03:41 PM
Locomotion Offline
Locomotion  Offline
Oh yea! Now I remember!
The arm has the 3/8" square hole, which is better to use.
It's been a while, but I think I hooked onto the tensioner bolt last time for whatever reason.
Thanks.
Re: How to install belt on 2004 Dodge Ram 1500? [Re: ZIPPY] #440800
08/18/09 11:39 AM
08/18/09 11:39 AM
Houma, Louisiana
Houma, Louisiana
Thanks for the info!!
My car 74 Duster mild 360/904/3.91 13.44/101.54 Son's car 75 Dart Sport 318/904/4.10 looking for a 360 or 408 2004 Dodge Ram 1500 Laramie 5.7 2010 Dodge Challenger R/T Classic B-5 6 speed 2010 Jeep SRT8 for the little wife
