Sure grip from 741 into 742 case keeping 742 gears. #440740
08/17/09 10:58 AM
08/17/09 10:58 AM
Denver, co
68charger440s Offline OP
Denver, co
Hello,
I have a 68 charger with a 440 stroked to 500". I have a clutch type sure grip in a 741 and I also have a non sure grip in a 742 case with 3:23 gears. I want to take the non sure grip 3:23 gears and case from the 742 and mate them up to the sure grip unit from the 741. My thinking is that I will end up with a 742 sure grip with 3:23 gears. Can anyone tell me if that will work, and what gotccha's I might run into?
Re: Sure grip from 741 into 742 case keeping 742 gears. [Re: 68charger440s] #440741
08/17/09 11:04 AM
08/17/09 11:04 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
That will work but before you do any disassembly, make sure you accurately measure the existing gear lash on the gear set you intend to use, and then be sure you set up the final lash exactly to match your measurement. Don't try setting the lash to what the factory calls for on a new set of gears cause it will probably be too tight for a used set of gears and may make noise. DAMHIK...
Re: Sure grip from 741 into 742 case keeping 742 gears. [Re: Sixpak] #440742
08/17/09 11:38 AM
08/17/09 11:38 AM
Denver, co
Denver, co
Thanks Sixpak! Will there be any problems with the bearings
Re: Sure grip from 741 into 742 case keeping 742 gears. [Re: 68charger440s] #440743
08/17/09 11:50 AM
08/17/09 11:50 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Remember that the ring gear bolts have left hand threads.
Re: Sure grip from 741 into 742 case keeping 742 gears. [Re: MoparforLife] #440744
08/17/09 11:56 AM
08/17/09 11:56 AM
Denver, co
Denver, co
That would qualify as a "Gotcha"
thanks
