Re: Tooth off on timing chain?........
[Re: dustergirl340]
#440247
08/16/09 09:26 PM
08/16/09 09:26 PM
RapidRobert
put your marks on TDC & see where the rotor is (whether #1 or #6) it'll be way off from the underside of the dist cap terminal. More details, what happened.
[Re: RapidRobert]
#440248
08/16/09 09:53 PM
08/16/09 09:53 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
Already done.
We set the timing at 35* at 3,000 rpm. It has very low vacuum (9"). But if you advance the timing to 42* we can get the vacuum up to 17".
Engine has a miss between 1,800 to 2,300 rpm. The engine runs better with a lot of advance but still has that stutter.
We've ruled out vacuum leaks.
[Re: RapidRobert]
#440249
08/16/09 09:53 PM
08/16/09 09:53 PM
I think if you pull the fuel pump you can feel for the slop in the chain. Does this maybe have the phenolic top sprocket? If steel, there's very little chance that it's slipped.
Quickest way, is that IF you know where the timing is supposed to be, and it's way off, it's slipped.
Take a wrench and rotate the engine cw/ ccw against the chain "slop." If it's 10* movement or more, I'd be suspecting slippage.
[Re: marvo451]
#440259
08/17/09 01:11 PM
08/17/09 01:11 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Are you sure the harmonic balancer hasn't slipped on its rubber ring, giving you incorrect timing with the timing light?
He already stated above that the TDC mark is right on with piston position.
[Re: dustergirl340]
#440261
08/17/09 02:55 PM
08/17/09 02:55 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Did this happen after the chain set was replaced? I believe there was a run of spockets (sorry don't know which manufacter) that were mis-marked out of the box. It maybe worth it to degree your cam.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: dustergirl340]
#440262
08/17/09 04:26 PM
08/17/09 04:26 PM
just checked, the timing chain (new chain) is dead on. Harmonic balancer is good
I could've sworn I posted this. Just exactly how did you check this?
[Re: Posest]
#440266
08/17/09 11:03 PM
08/17/09 11:03 PM
moparpollack
Lil Herman
Lil Herman
85086
I say slop in the distributor. Run a compression check to see if you didn't bend a valve.
#440267
08/18/09 07:11 AM
08/18/09 07:11 AM
Posts: 8,180 Detroit, MI
CokeBottleKid
Detroit, MI
Yeees, how did you check this? Need more backround, is there something new or is this the old motor you've been running 13s with for years?
[Re: dustergirl340]
#440269
08/18/09 12:18 PM
08/18/09 12:18 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I've seen results like this if the distributor drive gear is off a tooth, it gives all kinds of wonky timing values.
[Re: CokeBottleKid]
#440272
08/19/09 08:25 AM
08/19/09 08:25 AM
patrick
Grand Haven, MI
distributor drive gear location doesn't matter so long as the distributor vacuum advance has room to allow movement for proper timing setting...
Hers must have been severely worn, or maybe she fixed another problem inadvertently when she replaced it...
it does and it doesn't, depending on where you put the plug wires. if the DD gear is off (not pointing to #1 at TDC of #1), but you put the plug wires in the same orientation as usually shown, it will show odd advance numbers, because the rotor isn't synced up with the mark on the balancer. if you orient the plug wires so that at TDC of #1, the #1 plug wire is over the dizzy rotor, things will look OK relative to the timing mark on the balancer.
[Re: patrick]
#440273
08/19/09 11:41 AM
08/19/09 11:41 AM
You should be a politician. The "simple" way to say this is, that it "will be out of time" if the wires are in the wrong hole.
The ONLY REASONS that any factory manual specifies a certain way to install a dist. are:
So the assembly line folks can wrench, repeat
So the vac. advance sits OK
So the plug wires "lay" right
So a tuneup mech. sees what he expects to see.
There ARE a few engines that matter. One series are the GM V6's. On some of these engines, the dist. towers are "paired" two towers closer together, then a wide space, so if you get the wires off just one hole, it just won't run right.
When I got my first car, a 57 Chev 265, I didn't know there was a "right" way. I used to just drop the dist in and go.
