62 -65 k member #440099
08/16/09 05:32 PM
08/16/09 05:32 PM
somewhere out there
Billy no mates Offline OP
somewhere out there
Hi can anyone tell me if there is any visable difference between a 63 Dodge b/b & a 63 small block k member? Im just trying to work out if I have the correct one.
thanks
BillyNoMates
Re: 62 -65 k member [Re: Billy no mates] #440100
08/16/09 05:40 PM
08/16/09 05:40 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
v8 takes the same one.
Re: 62 -65 k member [Re: Billy no mates] #440101
08/16/09 06:19 PM
08/16/09 06:19 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
thanks
So why did you title this thread "62-65 k members", which I believe are close but different?
Re: 62 -65 k member [Re: jcc] #440102
08/16/09 08:16 PM
08/16/09 08:16 PM
Oklahoma City, OK
Dave64 Offline
Dave64  Offline
Oklahoma City, OK
What should it be titled?
Re: 62 -65 k member [Re: Dave64] #440103
08/16/09 08:28 PM
08/16/09 08:28 PM
N.E.Ohio
P
Polarabill Offline
Polarabill  Offline
P
N.E.Ohio
I have a 64 Polara and used the small block K-frame and Schumaccher(sp)mounts.
This would be so much easier if I knew what I was doing...
Re: 62 -65 k member [Re: Polarabill] #440104
08/16/09 09:12 PM
08/16/09 09:12 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
A 318 poly mtr. k frame will work with a b or rb mtr.
Re: 62 -65 k member [Re: Billy no mates] #440105
08/16/09 09:59 PM
08/16/09 09:59 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
thanks
Same k-frame mounts, just diff bolt-on motor mount brkts from a small to big block.
Re: 62 -65 k member [Re: earlybee] #440106
08/16/09 10:54 PM
08/16/09 10:54 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
62 K is different than 63-5
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: 62 -65 k member [Re: Dan Brewer] #440107
08/17/09 12:08 AM
08/17/09 12:08 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
early 62 is diff i know i have one ,late 62 is the same up to 65.
Re: 62 -65 k member [Re: Billy no mates] #440108
08/17/09 10:59 AM
08/17/09 10:59 AM
No difference between the big and small block '63 Dodge K-frame.
