Re: steel repop shaker hoods?
[Re: metalgod]
#439255
08/16/09 10:07 AM
08/16/09 10:07 AM
Posts: 4,799 ILL
MLR426
ILL
Doug, Gene Gregory 618-488-7941 manufactures the challenger shaker hoods, also BE&A has the most correct shaker ring as I'm told. P.S. I received your return call,the brake push rod I received was for a b-body and not an e-body. I have no e-mail address for you as I cleaned up my e-mails months ago. I have waited patiently for the return call and when you called I had no return number info. Thanks, Martin Wimberly logan426 perfplus@fairpoint.net
[Re: MLR426]
#439256
08/16/09 10:44 AM
08/16/09 10:44 AM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
www.restorick.com Has the challenger shaker hood conversion kits if you are interested in performing your own conversion. These are the former HARMS conversion kits which are super accurate and correct looking. The undehood shaker braces are virtually undistinguisheable from an original. This is the best way to perform an original looking shaker hood. But you have to perform the work on your own, or hire a professional body man to tackle the job. If done right, you will end up with a very nice, very original Challenger shaker hood for the fraction of the price of an original. I wouldnt hesitate to use one of these on an OEM restoration if done right. I have a Gene Gregory performed conversion on a cuda shaker hood (Got it along with a 71 vert I purchased) and I can tell you that the top hood skin tin cans a lot and it's very wavy. Also, his underbrace doesnt look exactly like an original, there are visible differences. I dont know if AMD already has the Challenger shaker hoods on sale.
[Re: cataclysm80]
#439259
08/16/09 12:40 PM
08/16/09 12:40 PM
Posts: 6,085 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
Depending on the cars scheduled production date, it may not have crumple zones in the hood. If that is the case, doing a conversion with the top notch Domingo/Resto Rick shaker kit may be the only option.
Anyone know if the AMD hoods have crumple zones?
Tav
the CUDA AMD hoods has NO crumple zones. A la 1970-style.
the Challenger AMD hood HAS the crumple zone. A la 1971-style.
If you want a year-correct hood, you will need a Harms conversion kit and a correct flat hood.
I plan on doing that for my 1971 'Cuda.
If you're not worried about correctness, then by all means, the AMD hoods are nice. Very little body work req'd to get them perfect.
Even OEM Shaker hoods were wavy, thanks do the huge die stamping the trim ring recess in a weak area (before the brace was spot-welded in).
