Re: Oil outlet fitting
[Re: Shatar4]
#438697
08/15/09 04:39 PM
08/15/09 04:39 PM
Posts: 25,796 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Do you mean the adapter fitting that threads into the top of the valve? If so it's the inlet and there are two sizes depending on the year.
The valve is threaded 1/2"-20, so that side of the adapter will always be that size but the flare fitting can be either 1/4" (P/N 2537386) or 5/16" (P/N 1618610).
