Rallye Instrument Cluster Voltage Limiter Question.
#438607
08/15/09 05:33 AM
08/15/09 05:33 AM
Posts: 2,179 Walton, Indiana
TimS
Walton, Indiana
Was wondering if anyone knew what the normal output voltage should be on an instrument voltage limiter. I believe I have a bad one on my 68 Super Bee that has me chasing my tail. I'm running a 160 degree thermostat and have a recored radiator in place but still during complete warmup and driving am getting in the 200 degree range on temp at the gage. I notice also my oil pressure gage seems to increase as well as I drive which is odd and really is what leads me to this. Again reading the temp gage it shows my thermostat opening at about 190. Another clue. I've tried 2 thermostats, 1 used 1 new and they perform the same. Also are these available in the aftermarket? Mine would be the 3 prong not the bolt on Ebody style. Thanks.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: Rallye Instrument Cluster Voltage Limiter Question.
[Re: 68greenbee]
#438612
08/15/09 03:59 PM
08/15/09 03:59 PM
TimS
Walton, Indiana
50 bucks? Ouch!! I'm too cheap I guess. I took mine apart this morning and found the wire wound part of the contact was a little burned as it made contact with the lower set. I took some emery cloth and cleaned those up. Got about 62 ohms across one of the terminals to the case thru that wire wound contact. The spare E body one I had read about that so I think I'm good to go. Put the little insulator board back in the can and hooked her back up again. Seems to work much better. My gages read much closer to what they should now. I notice Year One has an aftermarket one for about half that price. Seeing that, I tried the local NAPA but the guy I talked to didn't have a clue. I bet it's out there somewhere. 'O' Rielly's or someone like that maybe.
[Re: aarcuda]
#438617
08/17/09 06:35 AM
08/17/09 06:35 AM
TimS
Walton, Indiana
Recall what value of resistor you need to get the correct readings? Wattage needed also. Was going to look into a 1 watt precision resistor for that. I assume resistor to replace the coil of wire that has about 62 ohms to ground inside the little can. At least mine does now but I suspect that isn't quite right. After driving a while Saturday my gages seem to read a touch low now. Were I would expect to see my temp at 160 it's about 150. So my resistance is still a little off.
[Re: TimS]
#438618
08/17/09 07:43 AM
08/17/09 07:43 AM
Posts: 15,491 the boonies
aarcuda
the boonies
i dont recall what i used. but I got the instructions on how to build it out of a mopar magazine from the early 90's. they gave a parts list- i believe it was a radio shack 5v regulator and a capacitor. and it used the case of the original voltage limiter as the heat sink. So my voltage limiter looks original (except for the screw head that attaches the regulator to the case) and plugs right in to the cluster. also used heat sink grease on the regulator.
Im sure that info must be on the web somewhere
[Re: aarcuda]
#438619
08/17/09 09:48 AM
08/17/09 09:48 AM
TimS
Walton, Indiana
I see. Different approach than just using a load resistor to pull the voltage down. Wonder if anyone on the board here has access to that drawing. I've kept all my Mopar Muscle mags from way back when and probably have what you are talking about. Just a matter of finding the article.
