Hey Monte, Still hook w/ 150HP more and 120#'s less ?
#438379
08/14/09 11:16 PM
08/14/09 11:16 PM
Posts: 903 Saskatchewan, Canada
cudabin
Need some advice on what to expect with a new combination i will be trying in September. Changing to an aluminum 540ci motor...
We have a 2,900# 67 notchback cuda w/ driver, ready to race. Best ET with the 470ci motor on Gas was 9.56 at 143mph with a 1.32 60 foot
34" double adjustable ladder bars with Strange double adjustable coilovers and 110# hypercoils.
Front suspension is stock, with 3 way adjustable shocks set at 90/10 and MP drag race tosion bars. Have adjustable front travel limiters
Tire is a 10.5W - 31 MT Drag (new set) with 9 psi on a 12" rim.
Rear Shocks are set 3 clicks from full soft on both comp and ext.
We scaled the car with the 470 iron block and after installing the MP drag t-bars and after leveling them we found the following:
LF= 859 RF= 796
LR= 633 RR= 623
Total #'s = 2,911
It would hook good and carry the front end for 50 feet if launched on the transbrake around 3,400 rpm but would spin if ever went to 4,000 rpm or more...
On a "very well prepped track" we ran a 1.30 60 foot launcing at 4,400 rpm, but at SIR our home track the traction is not good.
We are now replacing the 470 iron motor w/ a 540ci Indy Aluminum block and Terminator Alcohol injection which will make 150 more HP and take 120#'s off the front end.
What should i do to the suspension to get it to hook with the increased power and less front weight???
Ideas please.
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Still hook w/ 150HP more and 120#'s less ???????
[Re: MR_P_BODY]
#438382
08/16/09 11:32 PM
08/16/09 11:32 PM
cudabin
Just looking for ideas as I will only have a couple of races left this year once the new 540 bullet gets installed...
any other comments?
Arnie
[Re: cudabin]
#438383
08/18/09 10:50 PM
08/18/09 10:50 PM
cudabin
No one else w/ experience in adding HP to a ladder bar car ??? Last try... Arnie
[Re: Monte_Smith]
#438386
08/18/09 11:57 PM
08/18/09 11:57 PM
Posts: 2,864 IN
Irun5snd8th
IN
As stated above I would be more scared of it hooking rather than not. Adding the Terminator alone especially since you are currently on gas is gonna send you to the moon if it hooks. I promise you that! I would get something a bit more adjustable for front shocks. You will most likely want to slow the rate of extension which requires a better shock. There is just not that much there with a 3 way adjustable.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: Irun5snd8th]
#438387
08/19/09 11:15 PM
08/19/09 11:15 PM
cudabin
Thanks for the input Guys! Chris, Yes i have wheelie bars. Should they be set up equal height, or do I set one side lower to steer the car straight...? Monte, I will start where you suggest, but if it spins, which thing would you change first? Soften rear ext? I do have front end travel limiters set at 5 inches right now before the tires leave the ground. Good starting point? Thanks again for the advice. Arnie
