Tell me about your race 408 please #437972
08/14/09 08:25 PM
08/14/09 08:25 PM
Sherman Texas
The Shocker Offline OP
Sherman Texas
I am just nosey and would like to know what your using for induction and ignition on your stroker 408 .You know,carb ,intake ,dist ,coil, ignition box ,jetting ,timing ,cam grind ,rockers ,etc.I am also curious as to your ET and mph.Im not a spy ,just a proud 408 Dart owner ,who is trying to learn what i can fast .Thanks for letting me look around under your hood online ...
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
Re: Tell me about your race 408 please [Re: The Shocker] #437973
08/14/09 08:42 PM
08/14/09 08:42 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
well I have a 416 I am running a M1 single plane,Quick Fuel 950 no PV square jetted at 86,MSD 6AL box MSD 8207 Blaster II coil,MSD crank Trigger with a old gutted dist welded up timed at 37 deg a small Erson solid roller 246/254@50 .592 lift with a 108 in at 108 with Indy 1.6 rockers car is 2962Lbs with driver has run 6.52 at 106 with a 1.41 60 Ft
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Tell me about your race 408 please [Re: The Shocker] #437974
08/14/09 08:46 PM
08/14/09 08:46 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Ok let's start at the top,
1050 dominator
Indy 360-3 intake
Mopar lg port Commando's
Probe flat top piston's 12.9-1 comp
72 truck block
Eagle crank and H beam rod's
MSD crank trigger ignition
MSD Distributor
.688/673 Comp roller
Crane ultra-pro roller lifter's
Comp push rod's
Erson w2/w5 rocker's.
Re: Tell me about your race 408 please [Re: dartman366] #437975
08/14/09 09:15 PM
08/14/09 09:15 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
414 W5 ported W5 M1 matched BG 1000 cfm no pv 89 square jetted msd 6al blaster 2 msd dstrib locked at 33* comp solid roller 260@.050 12-1 flat tops BME rods calies crank pro gram caps 73 block
