Voltage Regulator Options #437920
08/14/09 06:44 PM
08/14/09 06:44 PM
Simi Valley, CA
MoparJ Offline OP
MoparJ  Offline OP
Simi Valley, CA
Is there a voltage regulator out there that will provide a more consistant voltage, say between 13 and 13.5, rather than dropping to 11 or 12 when lights are on and at idle, and coming up to around 13 once engine speed increases? This would be on a 73 A body.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: Voltage Regulator Options [Re: MoparJ] #437921
08/14/09 08:26 PM
08/14/09 08:26 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
It is not a regulator problem, It is that the alternator is not puttingout enough to compensate for the draw at idle. It will help some if you put a smaller pulley on the alternator or better still upgrade to a later higher amp dual field hook up alternator system.
Re: Voltage Regulator Options [Re: MoparforLife] #437922
08/14/09 08:35 PM
08/14/09 08:35 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
A 73 A-body would be a dual field alternator. Pick up a MP blue regulator....P3690731. That will give you a constant 13.5 volts. Youll have some people telling you not to run one on the street, but Ive been running them for over 10 years on everything I own. Im not the only one. It couldnt hurt to look at the alternator, but that regulator is what youre looking for if you want to maintain a constant voltage
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Voltage Regulator Options [Re: 69L78Nova] #437923
08/14/09 08:58 PM
08/14/09 08:58 PM
Upper Midwest
Upper Midwest
OOPs missed that. But still very likely has the lowest output alternator still available. Many were used in low optioned cars.
Re: Voltage Regulator Options [Re: MoparforLife] #437924
08/27/09 10:21 AM
08/27/09 10:21 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
to the origianl poster.
I have one of these blue constant voltage regulators on hand still in the box. you can have it, just pm me an address I'll send it to you.
Re: Voltage Regulator Options [Re: gtx6970] #437925
08/29/09 03:26 AM
08/29/09 03:26 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Current and voltage are two different things. How does a high amp alternator prevent low voltage at idle? I'm thinking that the alternators are the same physical size. In order to flow more current, the wiring needs to be larger, thus reducing the number of windings in a given space, reducing the voltage generated per revolution within a given magnetic field.
Re: Voltage Regulator Options [Re: 375inStroke] #437926
08/29/09 10:31 AM
08/29/09 10:31 AM
Somewhere, maybe the "Mad electical" articles, someone did some research and found that some of the earlier alternators, EVEN THE HIGHER OUTPUT models, did not put out well at low rpms. I'm no design expert but I can see how this can happen. Tighter core tolerances, closer rotor to stator spacing, and overal improvements in design and core alloys over the years could be part of the reason. The FACT of the matter is, some alternator designs ARE better than others, and put out more current at low RPM. The reason the VOLTAGE sages is because the unit is simply not putting out enough CURRENT to supply the needed LOAD and the battery has to start making up the gap, thus the VOLTAGE drops.
Re: Voltage Regulator Options [Re: MoparJ] #437927
08/29/09 11:56 AM
08/29/09 11:56 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Actually a complicated subject. So, some quick facts:
> All else being equal, a "larger" (higher output ampere rating) alternator will increase voltage at the below-full-regulated-voltage RPM.
> Below this RPM, the regulator, if working properly, should be virtually "full fielding" the alternator.
> Reduced output is a symptom frequently caused by one (or more) bad diodes in the regulator.
> A smaller pulley does, indeed, increase low-RPM output. However, 1G Chrysler alternators don't live very long at high RPM (part of the rationale behind large pulleys on race Mopars). A better fix is a 65A. alternator with a larger pulley.
> All voltage regulator used on the street should be temperature compensated. Constant-voltage regulators run the risk of cooking the battery in hot weather and actually undercharging in cold weather.
> Internal regulators, e.g.: GM, are lousy at temperature compensation
> Most late-model Mopars actually vary the voltage in response to the battery temperature -- that's as good as it gets.
Rick
Re: Voltage Regulator Options #437928
08/29/09 11:59 AM
08/29/09 11:59 AM
Marlboro, NY, USA
Marlboro, NY, USA
The reason the VOLTAGE sages [sags] is because the unit is simply not putting out enough CURRENT to supply the needed LOAD and the battery has to start making up the gap, thus the VOLTAGE drops.
Megadittos. Excellent explanation.
Rick
Re: Voltage Regulator Options [Re: Rick_Ehrenberg] #437929
08/29/09 01:24 PM
08/29/09 01:24 PM
Very good point. On all three of my cars "back then" I had alternator problems. First time I noticed was the "light show" going on at night inside my '69RR alternator. The stator windings had rubbed raw from vibration, and shorthing between windings.
I figured my "heavy duty" alternator on my '70 sixpack car at 4-1, which means that at 6K engine RPM the poor alternator is turning 24 THOUSAND. I had a little trouble, there.
Re: Voltage Regulator Options #437930
08/29/09 02:45 PM
08/29/09 02:45 PM
Marlboro, NY, USA
Marlboro, NY, USA
There is some evidence that the last few years of the 1G Chrysler (Indy built) alternators (1960-up style) were ruggedized because they were also used on 2.2Ls.
Rick
