Caltracs A body ???
#437794
08/14/09 03:36 PM
08/14/09 03:36 PM
Posts: 6,295 U.S.
moparniac
U.S.
Got my caltracs today and there was no aluminum washers fir side to side on the front triangle up in the front spring hanger area... This is a mini tubbed dart... Are they necessary or what did you guys use.. Thx
Mopar Performance
Re: Caltracs A body ???
[Re: moparniac]
#437798
08/14/09 07:48 PM
08/14/09 07:48 PM
Posts: 5,080 organ
maximum entropy
organ
call me stone age, but i don't think this is a problem. assuming the pins will line up with your spring perches, the shackles almost never line up perfectly. that the beauty of leaf springs- super forgiving. just pull those babies in and go. when your done, check rear end housing alignment, and you'll be good.
[Re: sixpackgut]
#437801
08/14/09 09:09 PM
08/14/09 09:09 PM
Posts: 4,436 SO CAL
BB70DUSTER
SO CAL
and soon the pinion angle questions will start
Yup... he should have just bought one of my cars... LOL
[Re: moparniac]
#437807
08/15/09 09:34 PM
08/15/09 09:34 PM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
I guess the way the spring boxes are welded in it would have the springs inside more than the frame rail....
From the looks of this picture it looks like you put your boxs all the in so that they are flat with the out side of the frame. You didn't center the weld in boxs. That being said, you may have to buy those offset shackles for the rear. As for the front bracket of the cal-tracs that doesn't look like the ones that I got for the A-body with in board springs.
[Re: moparniac]
#437809
08/15/09 10:13 PM
08/15/09 10:13 PM
70dusterjohn
Deerfield, Ohio
I bought the car done and dr diff is sending me some offset hangers.... and yes this is the first time I am seeing caltracs with the aluminum pin like that myself... they do go up in there though!
Thats cool.. My buddys Dart was the same way with his cal-tracs, just used the off set hangers.. He had the early type cal-tracs, IIRC we spread the front boxs alittle to make them move alittle easier.. Good Luck, and it's looking good.
