Stock 5.9 Magnum with Air-Gap manifold & 650 carb HP? #437392
08/13/09 11:22 PM
08/13/09 11:22 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
If you have a good running 5.9 Magnum and replace the beer keg with an Air-Gap intake manifold and Eddy 650 carb what horsepower would you get? I think that the OEM rating was 245 hp with the TBI.
Re: Stock 5.9 Magnum with Air-Gap manifold & 650 carb HP? [Re: VITC_GTX] #437393
08/13/09 11:31 PM
08/13/09 11:31 PM
Southern Cal
Noblewk Offline
Noblewk  Offline
Southern Cal
I doubt that you would get more then 245.... The Cam isn't very much on the engine as it is. Intake, Headers and Cam then it will be working much better...
66 Dart GT, 402 11.18:109 Best 63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best 2000 Ram 2005 Durango Hemi.
Re: Stock 5.9 Magnum with Air-Gap manifold & 650 carb HP? [Re: VITC_GTX] #437394
08/13/09 11:41 PM
08/13/09 11:41 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I'd bet you'll pick up 40HP. Add headers and you should see 300HP.
Re: Stock 5.9 Magnum with Air-Gap manifold & 650 carb HP? [Re: VITC_GTX] #437395
08/14/09 07:31 AM
08/14/09 07:31 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
what you've described, with the exception of a regular 4bbl vs. the air gap is the 300 HP crate motor, which on westech's dyno for a MM article dyno'd at 305HP with 318 manifolds up to 325HP with headers (can't remember if it was hooker long tubes or TTI step)
stock mag 360's were rated 230-250HP net (through full exhaust w/all accessories) stock depending on year and model, the 20hp variation was all exhaust system & air box differences, IIRC the cam never changed from '92-02.
2017 Grand Cherokee Overland
Re: Stock 5.9 Magnum with Air-Gap manifold & 650 carb HP? [Re: VITC_GTX] #437396
08/14/09 07:52 AM
08/14/09 07:52 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
A very quick run with
1995 Magnum 5.9L specs on
Performance Trends Engine Analyser 3.2b computer program
using mods of
650 carb
dual plane intake manifold 1.72" effective diameter runner with 8 inch runner length flowing
shows 245 SAE hp at 4200 rpm
327 ft-lbs at 3200 rpm
with the stock factory streamlined Magnum manifolds and stock exhaust
286 SAE hp at 4400 rpm
364 ft-lbs at 4000 rpm
with a change to
forty-two inch long 1.625" internal dia primary
4 into 1 tube headers 6 inch long collector
and a 550 cfm rated aftermarket exhaust that gives less than 2 psi backpressure at 5200 rpm WOT
for 'standard dyno room' horsepower numbers
add 2% or more to the above numbers
Kevin at Performance Trends only claims that this engine simulation program comes within 7% of actual engine tests,
but that dyno to dyno variation is about that (or more)
Re: Stock 5.9 Magnum with Air-Gap manifold & 650 carb HP? [Re: 360view] #437397
08/14/09 10:56 AM
08/14/09 10:56 AM
Kalispell Mt.
HotRodDave Online content
HotRodDave  Online Content
Kalispell Mt.
Patrick is right. The crate motors rated at 300 hp have made 325(magazine hp) with TTI headers and the M1 dual plane. The truc motor has a slightly bigger cam and if you use the eddy air gap you get a better manifold so I would say you should make 325 real world HP easily. The carb may be just a hair small but not bad.
Re: Stock 5.9 Magnum with Air-Gap manifold & 650 carb HP? [Re: patrick] #437398
08/14/09 02:30 PM
08/14/09 02:30 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks for the information. I was thinking of picking up a good running 5.9 and making it a daily driver motor. $600 for a used motor and throw on an intake/carb/headers for 300-325 horse, not too shabby.
Re: Stock 5.9 Magnum with Air-Gap manifold & 650 carb HP? [Re: VITC_GTX] #437399
08/14/09 06:26 PM
08/14/09 06:26 PM
Frederick, MD
moparguy1967 Offline
Frederick, MD
I have pretty much the same setup you have listed. Im very happy with how it runs on the street. I planning on make a trip to the track this weekend to see what kind of a number it will run.
Re: Stock 5.9 Magnum with Air-Gap manifold & 650 carb HP? [Re: moparguy1967] #437400
10/14/09 07:52 AM
10/14/09 07:52 AM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
I have the same setup in my truck except a Holley 600. It will pin you back in your seat and off the line torque for a heavy vehicle is good with this engine.
