Re: Looking at a new converter.. [Re: dartman366] #437308
08/15/09 07:22 PM
08/15/09 07:22 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Car has ran a 1.30 60' @ 9.98.....(that's exceptional) I know I would'nt be touching the converter if it was me.
I think anything you find on top end will be negated by a loss in the 60'. That car works exceptionaly well in the first 1/8 mile, which is normally where a weak converter shows up most.... I would not screw with it, I think 9 times out of 10 you are probably going to slow car down with a verter change IMO.
Re: Looking at a new converter.. [Re: RyanJ] #437309
08/15/09 09:47 PM
08/15/09 09:47 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
The converter that's in the car now wont be touched so I can go back to the origional combo if needed, I am going to give this guy a try, he tell's me he can make it better, you don't learn nothing if you don't take a chance once in a while, just like I tryed another cam and that didn't make an improvement so I went back to the one you speced for me origionally.
Re: Looking at a new converter.. [Re: dartman366] #437310
08/16/09 11:15 AM
08/16/09 11:15 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Oh I love trying things..... that's all I do is make changes & see what works/does'nt & put it in the memory bank...... but I just think you're asking for alot to pick up something that already works exceptionally well. Like I said, I bet 9 out of 10 converters are going to slow the first 1/8 mile down... But have at it, it's your $ & your time/effort making changes. Hopefully you find something that will make car faster, but I just would'nt get your hopes up, kind of like the cam swap & intake swap..... when you have a combo that really seems to work well, it's very difficult to find a "magic pill" that will make drastic improvements.
Re: Looking at a new converter.. [Re: RyanJ] #437311
08/16/09 12:05 PM
08/16/09 12:05 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
Bill, I don't know but I think you may hit the tires harder with the bigger converter at the same stall and open up a whole new can of worms, tire spin. My Cuda works much better with the 8", no tire spin and better 60'. With the 9 1/2 converter, 300 less stall, it spins and 60 ft jumps around. Just something else to consider.
Re: Looking at a new converter.. [Re: RyanJ] #437312
08/16/09 12:46 PM
08/16/09 12:46 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Ryan,won't be doing anything untill after Norwalk, but I have to try, or I wont be happy and will always question it, one thing about it if it don't work I can still get most of my money back out of it, and don't take me wrong I do understand what you are saying, for what I have it does run quite well, and I am quite pleased with it.
Dan, I hear what you are saying, and if it does hit the tire harder and give me some traction issues, then that is more incentive to add a little (lot) more tire to the rear, like I have been thinking of doing anyway.
Re: Looking at a new converter.. [Re: Garceau] #437313
08/16/09 02:09 PM
08/16/09 02:09 PM
ky
68roadrunner Offline
ky
Many of the big names use great parts and the converters are very similar and all done very well.
ATI probably has the most stock/super stock type wins. BTE is probably the fastest growing in the past ten years. Coan has always been a staple and I wouldnt hesitate to run one again.
Us as racers get way too caught up in the "size" of the converter. There is so much more than the size of the converter and its relation to what it does in our cars. A 9 inch that stalls at 5k is going to have different characteristics than an 8 inch that stall at 5k. Stator, fin angle all come into play and directly effect the stall and more importantly the top end efficiency.
Personally in a bracket car I like my converter a little on the loose side. I will loose some ET but gain a bunch of consistency.
I would call around and speak to every company you want to, and see which one speaks to you the best and you form the best working relationship with. Keep them and continue to use them unless you have a reason not to. Personally I have been going with BTE for the past 8 years or so, I like how I am treated, I like what they have done for sportsman bracket racing and I like the people running and building the converters. Are they the best? Depends on what you define best with........
Your converter is (IMO) the single most important piece of the puzzle to make all cars perform their best.
good thing somebody likes BTE. they couldn't fix anything i sent them.
Re: Looking at a new converter.. [Re: dartman366] #437314
08/17/09 02:07 PM
08/17/09 02:07 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Bill, looking at your numbers, you seem to have the car running as good as it can(you have it optimized)your 60 foot for a car that generally runs in the low 10's is as good as anybody's i have heard of.
based on what i see, if you want to go faster i would put a set of indy heads on it and be done with it. Your MPH isnt indicitave of the car Et going much further you have a good working setup that is giving you all it has on tap, IMO. i would be shocked if a convertor swap picked you up anything.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Looking at a new converter.. [Re: dartman366] #437315
08/17/09 03:20 PM
08/17/09 03:20 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
I think I would agree with both Ryan and Don on this one Bill
