Re: Degreeing a cam in..
[Re: VernMotor]
#437222
08/13/09 09:44 PM
08/13/09 09:44 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I like duration at .050 /2 -32 268.5 /2 = 134.25 - 32 = 102.25 or your way. I have a milidon gear drive and you set the cam @ .050 then turn crank to desired BTDC number then line the top gear up to inner hub there are seven bolt holes. then go through various methods of checking @ .050 .0200 .050 before and after max lift and so on! I like where you are going to degree it help the big girl get moving!!!
[Re: BobsProFab]
#437224
08/13/09 09:50 PM
08/13/09 09:50 PM
Posts: 1,163 Newark, OH
Hunted Duck
Newark, OH
i do it @ .050 before and after max lift add then divid by 2
Bob
This is how I do mine also.
[Re: BobsProFab]
#437225
08/13/09 09:52 PM
08/13/09 09:52 PM
Posts: 1,532 off the grid
340B5
off the grid
I do it the same, after setting 0 the same way on the crank degree wheel.
Yeah, it's got a smallblock.
[Re: BobsProFab]
#437226
08/13/09 09:52 PM
08/13/09 09:52 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
Bob
I did that also..it come out the same way..
[Re: Dodgem]
#437227
08/13/09 09:54 PM
08/13/09 09:54 PM
VernMotor
Mt.Vernon ,Ohio
Yea I had it at 104.5 ..thought this might help
[Re: VernMotor]
#437228
08/13/09 10:01 PM
08/13/09 10:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Ok let talk about this some..I wanted my cam in at 102. numbers are intake open at 32 deg and close at 56.5 . that is @ .050 after opening and .050 before closing. Now there are two-three ways to do this.. Not saying any one way is wrong. This is how I do it.. might be wrong ??
add 32+56.5 + 180 = 268.5 div by 2 =134.25 - 32 =102.25 show me your numbers and how you do it.
Jamie thats the same way I check the numbers but when I install it I sorta cheat. I have a gear drive so I would (in your case) set the crank to 102 and have the #1 intake at the top with my indicator on it and slide the idler gear on... then make the before and after(.050) checks to see if its correct and adjust if needed
[Re: Hunted Duck]
#437229
08/13/09 10:05 PM
08/13/09 10:05 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Bob
Make that three
[Re: WILD BILL]
#437233
08/13/09 10:32 PM
08/13/09 10:32 PM
VernMotor
Mt.Vernon ,Ohio
Bob
Make that three
One thing comes in to play here is how your degree wheel reads ..my is broke in to 90 deg segments...not all degree wheels are this way.
[Re: VernMotor]
#437234
08/13/09 10:48 PM
08/13/09 10:48 PM
Posts: 43,180 Bend,OR USA
Cab_Burge
Your doing it the way the cam companys want you to I don't like doing the lobe centers that way so I do it at the valve retainers, I also always check the exhaust after getting the intake lobe center where I want it. This makes sure the cam lobe centers are ground correctly on both lobes, the exhaust lobe center should be retarded the exact same amount the intake lobe is advanced. IE Lobe seperation angles are 108, you install the cam with four degrees advance on the intake lobe, which means the intake lobe is installed at 104 max lift after top dead center, the exahust lobe max lift should be exactly at 112 BTDC
[Re: VernMotor]
#437235
08/13/09 10:50 PM
08/13/09 10:50 PM
WILD BILL
BROOK PARK, OH
Ari440
First you need to find true TDC. Use a stop and bring the piston up to it and record the reading (i.e. 10* to the right of 0). Now go backwards till the piston hits the stop. If the reading is the same (10* to the left of 0) you have TDC. If not adjust the pointer (or move the wheel) till the #'s are the same on either side of 0 TDC.
Now place your dial indicator on the intake liffter. Bring the lifter to max lift and zero the indicator. Now rotate untill you read .050 and record the #. Rotate back to 0 (max lift) and continue till you read .050 the other way. Record this #.
Add the 2 #'s togheter and divide by 2 and that is your intake CL.
[Re: WILD BILL]
#437236
08/13/09 11:09 PM
08/13/09 11:09 PM
MR_P_BODY
Bob
Make that three
I do the install like you guys are saying with the .050 before and after, add then /2 For what Cab is saying about checking at the valve, I dont usually check it there.... I just advance the cam basically to give more torque and compensate for the valve train loss
[Re: Ari440]
#437240
08/14/09 07:16 AM
08/14/09 07:16 AM
WILD BILL
BROOK PARK, OH
THANK YOU VERY MUCH BILL
[Re: BobsProFab]
#437241
08/14/09 08:07 AM
08/14/09 08:07 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
Bob
that's how I did mine. find max lift w/ the dial indicator, 0 it out, then go .050 on either side, taking degree measurements. add them up and divide by 2....I was checking at the lifter, heads weren't on the motor yet.
[Re: WILD BILL]
#437242
08/14/09 09:21 AM
08/14/09 09:21 AM
Posts: 205 Chicago,Illinois
nosboy
Chicago,Illinois
ABSOLUTELY CORRECT BILL!!! You HAVE to find the TDC of the PISTON and NOT the mark on the balancer.. I've seen balancers OFF BIGTIME!!!. Also, use the LIFTER and NOT the pushrod or rocker or valve.. There is angles involved in the relative positions of pushrods,rockers,,etc,etc,etc, that WILL throw off your readings... the LIFTER ITSELF,,,, not the piston inside the lifter,, the OUTSIDE WALL of the lifter... I put my cam at 102 and I am really impressed with the performance!!!! I have a 5000 stall convertor and the cam wakes up WAY BEFORE 5000 and I waste some power,,,but,, my challenger still runs 10:40's CONSISTENTLY and it idles pretty good sometimes.. The trick is to LEAVE the mechanical advance springs IN the distributor and NOT TO PIN the dist together,,, so it will start RIGHT AWAY all the time!!! the advance kicks in at around 1800 rpms and my car runs between 5000 and 7000 all the time
[Re: ProSport]
#437244
08/14/09 10:01 AM
08/14/09 10:01 AM
The big thing to remember here is --degree the cam to know where its at SO you know which way to go - if need be - AFTER you run it some--The recommended spot is a good GUESS at where it should be to get the desired results BUT if you are say 1/8 miler vs. 1/4 etc you may need to advance or retard to get the exact performance out of it that you are looking for--I have seen BIG inch engines make 50 Ft lbs more on the dyno by retarding a little I have seen small block 1/8 milers tear the chrome off the rear bumper and pull like a rocket in the 1/8 but run out of steam in the 1/4 so---going crazy over a degree or two is USELESS--a good smart racer will move it around a little to FIND where it needs ( after RUNNING it )to be for his combo and desired results OR if it dynos great and you are winning races WHO cares what it is degreed at? - except to be able to put it back in the same place after teardown - Getting picky over HOW to get there is missing the point IMO --just do whatever you do the same way every time. One of the best ways - accurate every time - is with the tool in the lifter bore that holds the mic and measures straight off the lobe--- make it run good for real --not on paper
[Re: B5 Bee]
#437246
08/14/09 11:39 AM
08/14/09 11:39 AM
WILD BILL
BROOK PARK, OH
When checking .050 before and after, turn it in it's normal direction, check .050 before, then .050 after, all in one direction. This will keep the chain tight and not add in the chain slop to your readings that will happen if you turn it back and forth.
Forgot about that
Last cam I degreed was in the Jr and it has no chain
[Re: ]
#437247
08/14/09 01:27 PM
08/14/09 01:27 PM
Posts: 527 alaska,usa
9secondsatellite
alaska,usa
measure off the lobe, go right to the source. the right tool and procedure will make it accurate every time.
[Re: Hunted Duck]
#437248
08/14/09 05:50 PM
08/14/09 05:50 PM
VernMotor
Mt.Vernon ,Ohio
Bob
I would like to see picture of you guys degree wheels..something don't add up here. just to take the 2 numbers and add and then div. Like my numbers..60 and 35 deg add them =95 div them by 2 =47 ???
[Re: goldmember]
#437256
08/14/09 11:27 PM
08/14/09 11:27 PM
Dodgem
Ontario, Canada
This is my small 11" wheel only one that will fit in the car. Have a bigger 14 or 16" real cool!
[Re: Dodgem]
#437261
08/14/09 11:35 PM
08/14/09 11:35 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
I don't own the smaller degree wheels,can you tell us the difference between them?
[Re: goldmember]
#437264
08/14/09 11:42 PM
08/14/09 11:42 PM
Dodgem
Ontario, Canada
I originally in the days before time had a direct connection 7" http://chucker54.stores.yahoo.net/mopdegwheel2.html then later as the earth began to cool I got the 11 " fits just right down in the car and now I have an 18" http://chucker54.stores.yahoo.net/mor18degprow.html The bigger they are the larger the numbers this does two things makes it easier to read and more accurate. I assume that's what your asking!!
[Re: VernMotor]
#437266
08/14/09 11:58 PM
08/14/09 11:58 PM
Cab_Burge
I had one Moroso degree wheel and one Mr Gasket, I gave one of them to 9secondPhil years ago, my point is that , as already pointed out, that some of the degree wheels will mislead you. I bought one form Comp Cams last year as the center of the old ones was getting worn and wouldn't always center good , The new one doesn't have a centering adapter so I have to hold it on center and tighten the bolt up and hope it stays in the center LOL The intake cylce begins with the intake valve opening before top dead center and ends up closing after bottom dead center with max lift somewhere bewteen 90 degrees after top dead center and 120 after top dead center, some people will call that 90 degrees before bottom dead center and 60 degrees BBDC The thing to remember on checking the cam timing on both lobes at .050 lifter rise is to add the 180 degrees between TDC and BDC that happens every time the valves open and close, if the intake valve opens at 35 .050 lifter rise before top dead center and closes at 56 degrees after bottom dead center you have 35+180+56 which equals 271 degrees intake valve duration at .050 Same thing on the other side but the exhaust valve timing starts before BBDC and closes ATDC, so its maximum valve opening is always going to occur before top dead center. On finding and checking lobe center you measure in relation to max lift .050 before and after, I measure in three places to make sure what the valve is seeing as it reaches maximum lift don't be suprised to occasionally see one degree variation on those three places My point on bringing this up is you can check it at .300 begore max lift or .050 BML, the lobe center will stay where the cam grinder made it As far as degree wheels, here is a picture of the two I have now, they are confusing if you don't use them as a way to measure cranksaft degrees only
[Re: goldmember]
#437267
08/15/09 12:01 AM
08/15/09 12:01 AM
MR_P_BODY
I was looking for accuracy and whether there was over 1 degree difference between them.I thought with all the pics,I might learn something important.
Well in a 11" wheel you have .095 per degree and in a 18" wheel you have .157 per degree... you can get much closer with the big wheel
[Re: goldmember]
#437270
08/15/09 07:48 AM
08/15/09 07:48 AM
patrick
Grand Haven, MI
mine's marked 0-180, not 0-90-0....
[Re: goldmember]
#437272
08/15/09 08:51 AM
08/15/09 08:51 AM
Posts: 16,925 NC
440Jim
NC
It's obvious the larger wheel SHOULD be more accurate. I was looking for some testing to confirm enough to replace my old unit. Guess I'll keep it.
The larger wheel is easier to read, but even a 7" when used carefully and correctly will get the job done "accurately". If you can repeat the setup and ICL less than 1 degree, that is all you need. The operator is more important...But better tools make it easier. IMO, setting the wheel to TDC is the place to spend time getting it the best you can.
When I buy a cam, I map the duration from 0.020" to 0.350" lobe lift, that is close to 0.050" before max lift depending on cam. Once you get to 0.050", the ICL should be the same (less than 1 degree different measurement). If you do it at 0.006, 0.008, 0.020, 0.050" you will see the difference in the opening and closing ramps.
