Re: Degreeing a cam in..
[Re: BobsProFab]
#437241
08/14/09 08:07 AM
08/14/09 08:07 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
i do it @ .050 before and after max lift add then divid by 2
Bob
that's how I did mine. find max lift w/ the dial indicator, 0 it out, then go .050 on either side, taking degree measurements. add them up and divide by 2....I was checking at the lifter, heads weren't on the motor yet.
[Re: WILD BILL]
#437242
08/14/09 09:21 AM
08/14/09 09:21 AM
Posts: 205 Chicago,Illinois
nosboy
Chicago,Illinois
ABSOLUTELY CORRECT BILL!!! You HAVE to find the TDC of the PISTON and NOT the mark on the balancer.. I've seen balancers OFF BIGTIME!!!. Also, use the LIFTER and NOT the pushrod or rocker or valve.. There is angles involved in the relative positions of pushrods,rockers,,etc,etc,etc, that WILL throw off your readings... the LIFTER ITSELF,,,, not the piston inside the lifter,, the OUTSIDE WALL of the lifter... I put my cam at 102 and I am really impressed with the performance!!!! I have a 5000 stall convertor and the cam wakes up WAY BEFORE 5000 and I waste some power,,,but,, my challenger still runs 10:40's CONSISTENTLY and it idles pretty good sometimes.. The trick is to LEAVE the mechanical advance springs IN the distributor and NOT TO PIN the dist together,,, so it will start RIGHT AWAY all the time!!! the advance kicks in at around 1800 rpms and my car runs between 5000 and 7000 all the time
[Re: ProSport]
#437244
08/14/09 10:01 AM
08/14/09 10:01 AM
The big thing to remember here is --degree the cam to know where its at SO you know which way to go - if need be - AFTER you run it some--The recommended spot is a good GUESS at where it should be to get the desired results BUT if you are say 1/8 miler vs. 1/4 etc you may need to advance or retard to get the exact performance out of it that you are looking for--I have seen BIG inch engines make 50 Ft lbs more on the dyno by retarding a little I have seen small block 1/8 milers tear the chrome off the rear bumper and pull like a rocket in the 1/8 but run out of steam in the 1/4 so---going crazy over a degree or two is USELESS--a good smart racer will move it around a little to FIND where it needs ( after RUNNING it )to be for his combo and desired results OR if it dynos great and you are winning races WHO cares what it is degreed at? - except to be able to put it back in the same place after teardown - Getting picky over HOW to get there is missing the point IMO --just do whatever you do the same way every time. One of the best ways - accurate every time - is with the tool in the lifter bore that holds the mic and measures straight off the lobe--- make it run good for real --not on paper
[Re: B5 Bee]
#437246
08/14/09 11:39 AM
08/14/09 11:39 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
When checking .050 before and after, turn it in it's normal direction, check .050 before, then .050 after, all in one direction. This will keep the chain tight and not add in the chain slop to your readings that will happen if you turn it back and forth.
Forgot about that
Last cam I degreed was in the Jr and it has no chain
[Re: ]
#437247
08/14/09 01:27 PM
08/14/09 01:27 PM
Posts: 527 alaska,usa
9secondsatellite
alaska,usa
measure off the lobe, go right to the source. the right tool and procedure will make it accurate every time.
[Re: Hunted Duck]
#437248
08/14/09 05:50 PM
08/14/09 05:50 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
Bob
This is how I do mine also.
I would like to see picture of you guys degree wheels..something don't add up here. just to take the 2 numbers and add and then div. Like my numbers..60 and 35 deg add them =95 div them by 2 =47 ???
[Re: goldmember]
#437256
08/14/09 11:27 PM
08/14/09 11:27 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
This is my small 11" wheel only one that will fit in the car. Have a bigger 14 or 16" real cool!
