Page 3 of 5 1 2 3 4 5
Re: another HHR fan question A Bodies ONLY [Re: bigtimeauto] #437036
08/15/09 10:18 PM
08/15/09 10:18 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Am I the only one who mounted my rad in front of the core support?
Maybe
Do you have any pics of that area? How big a radiator? What did you have to cut or remove to get it in there?
thanks
-Charles
Re: another HHR fan question A Bodies ONLY [Re: DrCharles] #437037
08/15/09 10:20 PM
08/15/09 10:20 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I'll take soome pics tomorrow. One thing is you need a glass hood because i did remove the latch.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: another HHR fan question A Bodies ONLY [Re: bigtimeauto] #437038
08/15/09 10:35 PM
08/15/09 10:35 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I suspected as much, given the location of the latch mechanism!
wouldn't it be possible to keep the steel hood and use pins or other hold-down mechanism?
-Charles
Post deleted by Defbob [Re: 1_WILD_RT] #437039
08/16/09 11:07 PM
08/16/09 11:07 PM
Re: another HHR fan question A Bodies ONLY #437040
08/18/09 10:45 PM
08/18/09 10:45 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Ok......
got my fan today .
Ive taken all the extra plastic off it i can to gain clearance.
It does fit , but theres maybe 1/4" from the fan motor to the 4 water pump pulley bolt heads. It fits nice and flush to the rad though .
Im moving it forward.
SO-- how did you guys fasten the fan to the rad , and the rad to the body (after cutting ) ?
Re: another HHR fan question A Bodies ONLY [Re: 493_DART] #437041
08/18/09 10:59 PM
08/18/09 10:59 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Re: another HHR fan question A Bodies ONLY [Re: 493_DART] #437042
08/18/09 11:03 PM
08/18/09 11:03 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
That 1/4" clearance is with your radiator in the stock position (no cutting of the core support)? hmmm won't work so good with a 3/8" motor plate...
Wonder what it would cost to have 3/8" milled off my WP housing to compensate for it?
I'd definitely like to see pics though
-Charles
Re: another HHR fan question A Bodies ONLY [Re: DrCharles] #437043
08/19/09 12:55 AM
08/19/09 12:55 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
-Charles
Here's where I'm at as of tonight---
I cut some of the rad support out and set the rad/fan in there . Now Ive got around 3/4" clearance - looks pretty good in there now
Im going to start making brackets tomorrow night , should have it all done some time Thursday - I will definitely post some pics .
Re: another HHR fan question A Bodies ONLY [Re: 493_DART] #437044
08/19/09 08:56 AM
08/19/09 08:56 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
-Charles
please post pics.. Im thinking im gonna do this with my 71 Dart
Mopar Performance
Re: another HHR fan question A Bodies ONLY [Re: moparniac] #437045
08/19/09 04:53 PM
08/19/09 04:53 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
I am also thinking of using that fan and would like to see pics, but it sounds like you cannot leave the radiator in the stock position?
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: another HHR fan question A Bodies ONLY [Re: 65signet] #437046
08/19/09 06:05 PM
08/19/09 06:05 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
You "could" ...
but you would have to either
1. run an electric pump
2. use some shallow head bolts for the pulley (kinda like converter bolts) ?
it would still be close ....
Re: another HHR fan question A Bodies ONLY [Re: 493_DART] #437047
08/19/09 06:10 PM
08/19/09 06:10 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I moved mine forward and also fitted a larger 31" rad at the same time.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: another HHR fan question A Bodies ONLY [Re: deaks] #437048
08/20/09 02:05 AM
08/20/09 02:05 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
All done-- works great -- have at least 3/4 to 7/8" clearance
Re: another HHR fan question A Bodies ONLY [Re: 493_DART] #437049
08/20/09 03:25 AM
08/20/09 03:25 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
How deep is the HHR fan.
best 60ft 1.36
Re: another HHR fan question A Bodies ONLY [Re: deaks] #437050
08/20/09 03:35 PM
08/20/09 03:35 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
How did you move the radiator forward did you cut the support?
Re: another HHR fan question A Bodies ONLY [Re: 65signet] #437051
08/20/09 03:46 PM
08/20/09 03:46 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
You have to trim the top edge and the sides to let the rad into the panel so that the rad sits tight to the upright of the front panel.
Here's a pic of one that's done
best 60ft 1.36
Re: another HHR fan question A Bodies ONLY [Re: 65signet] #437052
08/20/09 03:51 PM
08/20/09 03:51 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
i cut the support . gained 7/8" .
HHR fan is 3 1/2" thick after trimming --around 4 1/4" un-trimmed
Re: another HHR fan question A Bodies ONLY [Re: 493_DART] #437053
08/20/09 03:53 PM
08/20/09 03:53 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
hey deaks--whats the brand / part # on your Lower rad hose ?
Re: another HHR fan question A Bodies ONLY [Re: 493_DART] #437054
08/20/09 04:03 PM
08/20/09 04:03 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Sorry, that's not mine it's a guy over here, i've got the one with the spring inside and it works a treat.
Mick
best 60ft 1.36
Re: another HHR fan question A Bodies ONLY [Re: deaks] #437055
08/23/09 07:48 PM
08/23/09 07:48 PM
Marine Corps Base Hawaii
DemonKyle Offline
USMC LCPL
DemonKyle  Offline
USMC LCPL
ok heres a few questions on the topic that i didnt see before.
1. All of this appears to be done with big block abody's and the mods to make it fit seem to be minimal. Based off this, there shouldnt be any clearance issues with a SMALL-block abody?
2. As to the post of the battery dying out due to a high draw even with the denso alt, most of you don't seem to be having an issue with this. However, how many of you run your car on the street which is where these issues seem to take place at?
The reason for the second question is cause this car will see more of the street than it does the strip where as your cars seem to see more of the strip than the street?
Thanks ahead of time you guys
