Re: another HHR fan question A Bodies ONLY
[Re: LoneMopar]
#436999
08/13/09 06:51 PM
08/13/09 06:51 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
ok Ron- im not afraid to do any "trimming" , seems like it would only need moved maybe 1/2" ? wondering if anyone has fit this fan on the front side? Steve , i already have that special tool
[Re: His and Her 69's]
#437001
08/13/09 07:56 PM
08/13/09 07:56 PM
Posts: 6,295 U.S.
moparniac
U.S.
wonder how the fit would be with a drop in WP unit....
Mopar Performance
[Re: 440Jim]
#437003
08/13/09 08:39 PM
08/13/09 08:39 PM
Posts: 1,633 Jacksonville, NC
RonP
Jacksonville, NC
How many amps does it draw? I like the built in fan shround to the radiator edges.
I will look through my notes as I know I checked it and if not, I will tomorrow after work. The thing moves a ton of air and is so quiet.
[Re: RonP]
#437005
08/13/09 11:52 PM
08/13/09 11:52 PM
493_DART
Worst Weather USA
I hope my stock style alt. will be enough
the only other thing it runs is my 7 amp fuel pump
[Re: 493_DART]
#437006
08/14/09 12:34 AM
08/14/09 12:34 AM
Posts: 4,247 Newfoundland
codfish
Newfoundland
I'm watching this with great interest. I only have about 2 5/8" between my rad, and my MECHANICAL waterpump. Anyone fit one in an A-body with a mechanical wp? codfish
[Re: ProSport]
#437008
08/14/09 01:33 AM
08/14/09 01:33 AM
493_DART
Worst Weather USA
ProSport-- looks like you moved the rad forward a little ? how much ? i have a stock style water pump also Codfish..... Im gonna make this damn thing fit........yes i broke out the credit card tonight and ordered...... $60.75 to my door
[Re: 493_DART]
#437009
08/14/09 07:35 AM
08/14/09 07:35 AM
Posts: 6,295 U.S.
moparniac
U.S.
How many cfm of air does that thing flow.... 493dart where did you order yours from.. thx
Mopar Performance
[Re: moparniac]
#437011
08/14/09 02:04 PM
08/14/09 02:04 PM
493_DART
Worst Weather USA
i heard 3000 at least .
rockauto.com $60 shipped
[Re: 493_DART]
#437012
08/14/09 02:15 PM
08/14/09 02:15 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
A word to the wise, i was given by a member here. With anything close to a stock charging system , the HHR fan will flat eat up a battery in a mighty short time. A guy told me he had a 50 amp denso on his car and with that fan, ran out of juice on a sortie on the street one night because of how much juice that HHR eats. That is the only reason i dont currently have one, and just bought a much lower amP draw new fan for my car....aa i have a stock alt, not even as good as his Denso that didnt cut the mustard. Your results may vary
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#437014
08/14/09 02:27 PM
08/14/09 02:27 PM
RonP
Jacksonville, NC
I don't have a stock alt, but I am going to measure the draw tonight when I get off work. if I remember correctly it drew way less power than most previous fans I have had. Also, since the swap I have noticed zero difference in battery charging or anything electrical related. as mentioned though, like everything on here, your results may vary.
