best roll cage for a-body? #436620
08/13/09 12:11 PM
08/13/09 12:11 PM
LI, new york
gmachinedart1 Offline OP
LI, new york
I'm considering installing a 4 or 6 pt cage in my 70 dart so I can properly /legally mount my shoulder harnesses.Who makes the "best" bar for this application?(fitment/quality)
What are the advantages/disadvantages of going with a chromolly bar?(weight,strength,cost)
thanx
justin
Re: best roll cage for a-body? [Re: gmachinedart1] #436621
08/13/09 12:19 PM
08/13/09 12:19 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
I had a chassie shop build me my hoop and I finished it from there. I just want something that was tight to the roof and most kits that I saw where to low..
As for chromolly they say its stronger but your useing thiner pipe so I'd say its a wash, that being said the molly is lighter than mild steel but again because its thinner, Is it worth the extra money to save 30 lbs. not for me, plus anything you want to add to it later needs to be tig welded. Use the extra money you'd spend on the molly and buy better heads or a new carb, I think you'd see more of a return.
Re: best roll cage for a-body? [Re: gmachinedart1] #436622
08/13/09 12:21 PM
08/13/09 12:21 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
I would get a Comp engineering 6 point bar and only install the drivers side door bar and leave the passenger bar off as its pictured here.. You only need a 5 point bar for your car to run under a 11.49 I think..Phill
Re: best roll cage for a-body? [Re: 9 Sec Phill] #436623
08/13/09 05:59 PM
08/13/09 05:59 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
Mine is a 5 point Cromoly from Morriston.
SRT DEMON ONE SEAT
Re: best roll cage for a-body? [Re: Ron Silva] #436624
08/13/09 06:12 PM
08/13/09 06:12 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
We bought the Comp Engineering 8 point bar for my sons 72 Dart. It worked good. Ron
Post deleted by Defbob [Re: gmachinedart1] #436625
08/13/09 06:14 PM
08/13/09 06:14 PM
Re: best roll cage for a-body? #436626
08/13/09 06:25 PM
08/13/09 06:25 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
One more. Ron
Re: best roll cage for a-body? [Re: 383man] #436627
08/13/09 07:13 PM
08/13/09 07:13 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
S & W did mine.
Re: best roll cage for a-body? [Re: 383man] #436628
08/14/09 09:53 AM
08/14/09 09:53 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Ron, were those door side bars pre-bent, or did the installer do that? Can't recall ever seeing a pre-made kit come with pre-bent side bars like that...
Re: best roll cage for a-body? [Re: Sixpak] #436629
08/14/09 11:22 AM
08/14/09 11:22 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
We just installed one from S&W and it was nice. I liked the prenotching that they do. Not much cutting or notching needed. If you have any issues, they are fast to help out.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: best roll cage for a-body? #436630
08/14/09 05:25 PM
08/14/09 05:25 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
The best and nicest rollcage is one that is custom built by a chassis shop.
A roll bar that is legal has to be chrome moly. The reason is, can't find anyone who manufactures 1.75" Chrome moly tubing in a .083" wall. The reason you run Chrome moly which is heavier than mild steel by volume is. The chrome moly is much stronger than mild steel and requires thinner material. A basic roll bar requires 1.75 tubing where a cage only requires 1.625 tubing. Phil is right a 5-point is all you are required, but it does nothing for the passenger side of the chassis. If you connect it with 6" by 6" plates you have done little to support the car anyway.
If you have the funds there is no substitute for a chrome moly 12 point cage. Which by the way is 75 lbs. minimum lighter that mild steel. A chassis shop is forced to tig weld chrome moly. Tig weldsare much better looking than wire welds.
I started with a wire welded mild steel roll bar. Two years later I was cutting it out to replace with chrome moly. Do what you want just think about where you will be in a couple years and what money you may piss away to changes.
There is nothing wrong with a mild steel cage if that is all you ever want.
Leon
Re: best roll cage for a-body? [Re: Sixpak] #436631
08/17/09 01:33 PM
08/17/09 01:33 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes they were pre-bent as thats the way they came. Sorry I took so long to get back to you as I have been sick the last 3 days. Ron
