8.90's some progress.. #436615
08/13/09 11:48 AM
08/13/09 11:48 AM
Central,Ohio
FASTFISH420 Offline OP
Central,Ohio
Well..went to NTR last night..have not had the car out for over amonth..the track was stuipid slick..1st pass was like a ice rink aborted at 1/8 mile..2nd pass went towards the wall on wheelstand aborted run..3rd pass after waiting 2 hours staged the car and let my finger off the transbrake and went right into 2nd gear 1 second into the run it went a 5.69 in the 1/8 and 8.94 in 1/4 at only 149.mph..not bad for a blown run..this is the motors 7th pass and 4th full pass all year..weather was steamy at 73degrees and 78% humidity.should go some 70's maybe a high 60 in good weather and track..need to dump this 727 it does not like 9000rpm..way to heavy.
Probably wont get it out till Norwalk Classic for some more test runs and seat time...
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: 8.90's some progress.. [Re: FASTFISH420] #436616
08/13/09 11:59 AM
08/13/09 11:59 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
KOOL, those are some good numbers for sure. Where were you at last night.. Any track I know. Anyhow looks good...
Re: 8.90's some progress.. [Re: 70dusterjohn] #436617
08/13/09 12:03 PM
08/13/09 12:03 PM
Central,Ohio
Central,Ohio
National Trail Raceway..
